favorite additive?
Old Jun 26, 2010 | 07:51 PM
  #31
FORDF250HDXLT's Avatar
FORDF250HDXLT
i would think if you ran WVO you would just use a devoted tank.start the engine on diesel until warmup,then switch to WVO tank.5 minutes before you reach your destination switch to diesel tank again,so the pump and filter etc are all flushed though with pure diesel and ready to cold start next time with.
sounds easy enough i guess in theory lol.
Old Jun 26, 2010 | 08:28 PM
  #32
WarOzz's Avatar
WarOzz
Heck i usually remember to switch tanks about the time it starts sputtering at me
Old Jun 27, 2010 | 08:38 AM
  #33
gumper 123's Avatar
gumper 123
how much atf should one put in a tank?
Old Jun 27, 2010 | 09:30 AM
  #34
cornking's Avatar
cornking
I usually put in 1 pint every 3rd tank.
Old Jun 27, 2010 | 10:05 AM
  #35
Otahyoni's Avatar
Otahyoni
For all those who love ATF, could i run 75 Fluid?
http://www.countrymark.com/userfiles...F_75_FLUID.pdf
Its a tractor trans/hyd fluid that we use at the farm. And it's green, not red.
Old Jun 28, 2010 | 02:00 PM
  #36
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Type F ...
Depends on what you need, if you are trying to clean up the system ... I use a quart for 10 gallons, for normal every day use I use a quart for 50 gallons.
-Enjoy
fh : )_~
Old Jun 28, 2010 | 02:25 PM
  #37
wreckinball's Avatar
wreckinball
Type F is getting hard to find around here. Festus, do you see any additional smoke runnin the atf??
Old Jun 28, 2010 | 03:02 PM
  #38
Festus Hagen
Methanoholic
When mixed heavy, 1 quart to 50 no...
Type F is getting hard to find anywhere, but it's still available cheaply at most parts houses, not at convenient stores, I don't have any personal experience with anything else.
-Enjoy
fh : )_~
Old Jun 28, 2010 | 09:46 PM
  #39
Otahyoni's Avatar
Otahyoni
What do you think of the 75 fluid, Festus?
Old Jun 28, 2010 | 10:03 PM
  #40
FORDF250HDXLT
1 quart of ATF per 10 gallons is way more than the cost of 4 oz per 10 gallons of diesel kleen today though(and that's mixing more than called for even.)
Old Jun 28, 2010 | 10:24 PM
  #41
Otahyoni's Avatar
Otahyoni
True as that may be, i can get the 75 fluid free...
Old Jun 29, 2010 | 12:11 AM
  #42
wreckinball
That's the super cleanu dose. Kind of like putting a whole bottle of diesel kleen in a tank to clean things up. Doing that, the dk is more expensive. If anyone else is like me you don't get 7 treatments out of a bottle of dk. If you dose the ATF right, you should get almost 7. Here in bc that would be a 50% price reduction if the ATF does what it is said to do.
Old Jun 29, 2010 | 12:39 AM
  #43
Festus Hagen
Methanoholic
Never heard of it ...
-Enjoy
fh : )_~
Cam_Man595
Nov 8, 2011 04:24 PM
jchosler
Feb 3, 2010 09:36 AM
jeff wilson
6.4L Power Stroke Diesel
Dec 1, 2007 02:53 PM
Wingedpig
General Diesel Discussion
38
Feb 17, 2007 11:33 AM
Boss300
Nov 18, 2004 08:18 AM
