favorite additive?
Old Jun 24, 2010 | 05:28 PM
iverger's Avatar
iverger
I'm fortunate enough to have a couple of Exxon stations that sell BioDiesel B6-20 near me. Been using it in both my wife's Cummins and my IDI without additives for months now. Both trucks absolutely love the stuff. My wife's truck went from 18.5 mpg long running average to 20.2. I haven't done mpg on mine yet, but after about the second set of tanks or so a slight injector knock I had went away and my 10 second cold start cranks are now just 2-3 seconds.
Bob
Old Jun 24, 2010 | 05:42 PM
94 smokin stroker's Avatar
94 smokin stroker
well i just cant bring myself to run bio in my truck just gives me bad feelins i kno its good but i never will unless i get paid to
Old Jun 24, 2010 | 06:52 PM
oreocreaming's Avatar
oreocreaming
ya, i wish there was a place near me. heard good stories about it cleanin your fuel system.
Old Jun 24, 2010 | 07:59 PM
iverger's Avatar
iverger
I should add that I was an avid Lucas user before the BioD. Used it in both trucks almost every fill-up and I never noticed a difference until I switched.
Old Jun 25, 2010 | 10:15 AM
WarOzz's Avatar
WarOzz
For me its good old diesel kleen in every tank and sea foam before oil changes.
Old Jun 25, 2010 | 02:40 PM
cornking's Avatar
cornking
Originally Posted by Festus Hagen
I don't use additives very often, however when I do, I use Stanadyne Performance Formula unless I'm specifically looking for lubricity then I use the Lubricity Formula.
I've tried many over the years and I still prefer ATF, However I do not like taking the risk and will not recommend it to others except maybe in extreme cases and I also explain the risks that goes along with it's use.
-Enjoy
fh : )_~
Festus
Why do you like ATF? What are the risks in using ATF?
Old Jun 25, 2010 | 02:45 PM
johnboggs21's Avatar
johnboggs21
Originally Posted by cornking
Festus
the risk of using ATF is having a law enforcement agent dipping your tanks and him coming up with red fuel. Offroad fuel is dyed red because its offroad use only and does not have highway taxes paid on it. Adding ATF to your fuel will make regular taxed fuel look like untaxed offroad diesel.
Old Jun 25, 2010 | 04:19 PM
oreocreaming
ya, its rare that a cop around here would look. ive gone through the scales even easily 5000 times in the last 4 years and not once have they asked.
Old Jun 25, 2010 | 04:37 PM
cornking's Avatar
cornking
Since I live south of the border, I don't have a lot of choices when it comes to additives. It is either Bardahl or ATF.
I use ATF. It goes for about $2 a quart.
I don't think they have "RED DIESEL", just regular diesel for everyone here.
Are there any other negatives than color?
Old Jun 25, 2010 | 10:25 PM
WarOzz's Avatar
WarOzz
The only drawback to ATF is the color other then that imho it does just as good a job at cleaning out the fuel system as any additive on the market and it's a whole lot cheaper.
Old Jun 26, 2010 | 12:28 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Like has been said, The color is the only hazard, You don't have that concern ... use ATF your IP will love you!
-Enjoy
fh : )_~
Old Jun 26, 2010 | 02:29 AM
peruses's Avatar
peruses
I keep at least a 10% blend of biodiesel in the tanks usualy much higher
only use aditives when I cant get the biofeul and even that wasn't enouf on my last road trip the thinner fuel found lots of ways to leak
Old Jun 26, 2010 | 09:24 AM
  #28
tabascom16's Avatar
tabascom16
A little bit of bio or WVO. Been through 3 IP's because the diesel wasnt keeping the internal high pressure pistons lubed enough. Mixing some of these in the with the diesel stopped that right away.
It is great these old engines will run on just about anything and spare parts/engines are so dirt cheap.
Old Jun 26, 2010 | 04:44 PM
  #29
peruses's Avatar
peruses
WVO cqn be a real bad idea,
good for the injection pump but it tends to settle out and burn straigh while the motor is cold
if that happens it'll foul up your rings
Old Jun 26, 2010 | 06:46 PM
  #30
94 smokin stroker
ya like i said i shy away from that stuff ive only heard bad things
