Blowing Fuses
Old Jun 23, 2010 | 04:09 PM
eagletwingrl's Avatar
eagletwingrl
Exclamation Blowing Fuses
We have a 1995 Ford F-Super Duty wrecker - keeps blowing fuses - exspecially for the brake. Everytime they put new ones in the they blow - anyone got any ideas?
Thanx!
Was just advised that a Lincoln steering column was place in the truck since the old one was trashed - good reason to be blowing fuses?
Old Jun 23, 2010 | 11:32 PM
lmd91343's Avatar
lmd91343
Which circuits? What size fuses are used in those circuits?
Does the brake light fuse fail before or while use press the brake?
Was the truck ever wired for a trailer?
Was the "Wrecker" portion wired by Ford, the dealer, an aftermarket company, a backyard mechanic?
Old Jun 24, 2010 | 01:05 AM
LCAM-01XA's Avatar
LCAM-01XA
The Lincoln column has different wiring from the truck column, maybe something got messed up under the dash where the two wiring harnesses meet? Also out of curiosity, can you post pictures of said Lincoln steering column?
Old Jun 24, 2010 | 04:59 AM
Slip ford man's Avatar
Slip ford man
I had this problem last year...traced the wires to lens, found chaffed area on wire.
billy big truck
Nov 22, 2014 06:13 AM
ralleyclimber
Apr 28, 2014 11:30 AM
lilbit67
Jan 10, 2011 03:30 PM
tjbeard
Electrical Systems/Wiring
Oct 22, 2005 04:23 PM
billyb
Dec 19, 2000 03:28 PM
