fuse keeps blowing
Old Oct 22, 2005 | 08:30 AM
tjbeard's Avatar
tjbeard
fuse keeps blowing
Ok, I have a 1999 F-350 with 2tanks. one stock and one ad on. Every time I try to switch tanks The inline fuse next to the toggle switch keeps blowing. any suggestions where this problem is?
Old Oct 22, 2005 | 09:32 AM
Ultraute's Avatar
Ultraute
In which switch position does the fuse blow? Or is it only when you change the switch that the fuse blows?
Old Oct 22, 2005 | 01:35 PM
tjbeard's Avatar
tjbeard
only when I change the switch
Old Oct 22, 2005 | 04:23 PM
Franklin2's Avatar
Franklin2
You are going to have to crawl under the truck and find the solenoid that switches the fuel lines. Look at all the add-on wiring. Look at the wiring going to the add-on tank. And also look at the wiring where it goes through the firewall.
People's wiring practices are sometimes not very good, and a wire is probably rubbing somewhere.
ralleyclimber
Apr 28, 2014 11:30 AM
thejim42
Apr 12, 2013 10:19 AM
anotherlawnguy
Jul 10, 2011 03:48 AM
Layson
Sep 3, 2010 11:51 PM
jschloes
1983 - 2012 Ranger & B-Series
Sep 17, 2003 09:29 AM
