Sponsored by: Real Truck
brake light fuse
Old Jan 10, 2011 | 01:28 PM
lilbit67's Avatar
lilbit67
brake light fuse
touch the brake pedal and fuse blows instantly any one have an idea
Old Jan 10, 2011 | 01:38 PM
gearloose1's Avatar
gearloose1
Take all the bulbs out and see if it still blows
Old Jan 10, 2011 | 02:44 PM
lilbit67's Avatar
lilbit67
brake fuse
it still blew with all the bulbs out
Old Jan 10, 2011 | 02:47 PM
gearloose1's Avatar
gearloose1
Disconnect the rear harness to isolate it to front.
Old Jan 10, 2011 | 02:56 PM
lilbit67's Avatar
lilbit67
i tryed it and it still blew
Old Jan 10, 2011 | 03:21 PM
BareBones's Avatar
BareBones
Somewhere presumably on the shaft supporting the brake pedal is an electrical switch, hopefully with a slide-on connector to attach the wire to the switch.
At this point it would be useful to know what the resistance is between this wire and the chassis ground. If its close to zero ohms, you have a dead short somewhere, if its higher that would probably indicate corrosion. Cheap meters can be purchased for under ten bucks.
On the other hand, unless you've been off-roading or otherwise have made some mods recently, the problem is most likely some corrosion or obviously broken part in the brake lights themselves, which you can generally see once the lens is removed.
Another reasonable prospect would be the possibility that some movement in/around the brake pedal, has cut into and shorted the brake circuit wire.
Old Jan 10, 2011 | 03:30 PM
lilbit67's Avatar
lilbit67
thanks trying the switch its a 10 dollar item at autozone
geminijay313
May 23, 2014 11:45 AM
mdacton
Oct 10, 2008 05:10 PM
Trucker51
May 20, 2008 03:27 PM
99EX44
Jan 30, 2002 09:02 PM
