Go to Fuel Injecton or stay carb?
Originally Posted by Shark Racer
The adaptability and combustion control are why cars leave the factory with EFI.
You misinterpreted me and even then, didn't quite give correct advice. You're not tuning to just an engine - you're tuning to an engine, a transmission, a car, an elevation, a fuel type, etc.
EFI isn't as scary as you think it is. If you can swap gears in a rear axle and wire up an aftermarket tach, you can deduce what's going on with an EFI system.
Swapping gears in a rear axle is nowhere NEAR as easy as wiring up an aftermarket tach! Properly changing gears is an art all by itself; it is very easy to ruin expensive gear sets if not set properly, not to mention the labor involved is much more than wiring up an aftermarket tach. There are a lot of old timers who cut their teeth on carburetors who can wire up an aftermarket tach all day long, but scratch their heads when it comes to modern electronic fuel injection.
Changing the subject a little...
Since it sounds as if you have been around a lot longer than I have, and was driving vehicles before I was old enough to know, what was/is your opinion of the once state-of-the-art "feedback" carburetors that shared characteristics of carburetors AND electronic fuel injection that were common in the mid 1980s, and that was once on my own 1985 F150?
...and don't forget EMISSIONS. Since EFI is constantly self-tuning itself for optimum economy and emissions, they tend to run cleaner without the owner having to do anything about it. In the past, most people didn't take the time to properly tune their vehicle for changing conditions, and that is a big reason older carbureted vehicles were considered "dirty."
This 99% scenario is where a carburetor will have to be retuned; there is some adaptability via the air-bleeds and other systems, but nowhere near as much as EFI.
I don't think EFI is really all that "scary." Between my wife and I, we have four vehicles between us and only my F150 is carbureted. I would never switch out a perfectly good EFI system in favor of a carburetor.
What I have learned is that with the right tuning, a carbureted vehicle can run just as good as any modern vehicle, PROVIDED you understand what a carburetor can and can't do without input from YOU.
Anyhow.
I think feedback carburetors were a decent "bridge" design between carburetion and injection, but were limited by the technology of the time and also still had many of the limitations presented by carburetors. (obviously)
The CCC was basically a regular Quadrajet with computer controlled primary jets. The secondary operation was completely mechanical. I never had an opportunity to drive the 80 'vette to elevation but I'd bet it would have had slightly better off-idle response.
The biggest issue with carbs is the fact that mixture flow depends primarily on vacuum signal from the motor and no other input factors.
on
The engine wiring harness on a '90 is almost completely seperate from the rest of the vehicle.. the exceptions are power and ground and the check engine light, and since you have a donor vehicle right there this won't be too hard and should not cost you anything. The '90 also has a much simpler fuel system than your '85.. just a high pressure pump in the tank and two lines up to the motor.. no selector valve or booster pump on the frame, so I'd also suggest you move that over. The emissions system(air injection)on this motor does not affect engine operation so most of it can be deleted, that includes the air pump and all the plumbing and valves on top of the motor and those that run down to the exhaust. To avoid computer codes you just need to retain the TAB and TAD solenoids mounted next to the coil and keep them electrically connected. I'd also suggest you ditch the complete stock exhaust system and install shorty headers and an aftermarket Y pipe, doing so will really wake the motor up.
jeffp8
09-14-2015 04:17 PM
Jagesage
08-13-2015 02:59 PM
k-mann10
05-15-2014 07:09 PM
