Have an Edelbrock carb on the 351W in my 74 F100. While trying to tune the carb I found that I can completely close the idle mixture screws and the engine still runs. Should shut down due to lack of fuel. Only thing I can figure is the carb is still flowing fuel. My thought is that the fuel pressure is to high causing it to dump fuel. Any other ideas?
Might try changing metering rods and jets to a smaller size by pulling the top off the carb and or springs. You can just try changing metering rods to start with. I believe 5 to 7 psi is what an eddelbrock calls for do you have a fuel regulator? Hope this helps I haven't messed with them a whole lot but thats my thought
If you were overflowing the floats you would more then likely have fuel pouring out of your carb. 5 to 7 psi is correct. A stock Ford fuel pump can over pressure an edelbrock carb.
I seem to remember my last edelbrock would run like crap with them closed but not die. Either way you don't run with them closed anyway. Run them in until they stop back them out 1.5 turns. Warm up your truck completely, then tune the idle mixture to highest vacuum at idle. Last adjust your idle speed.
I did install a fuel pressure regulator but haven't checked the output pressure. Will do that today. With the engine warmed up adjusting the screws has very little to no effect on idle. Since the engine runs with both screws closed there has to be fuel getting through the carb from somewhere and I can only figure overpressure is causing this.
Might have the idle stop screw open too far. Close the plates down if possible. If this is not an option, like it won't run with plates closed, see if you can open the secondary plates slightly allowing more air, then close the primary plates to allow for proper idle speed. It sounds like your throttle plates are open far enough that it is allowing for fuel to be pulled from the transition circuit.
