quick help please!
Old Jun 19, 2010 | 01:09 PM
oreocreaming's Avatar
oreocreaming
quick help please!
ok, runnin the wires for my engine swap. something on the new ip that my old one doesnt have, not sure what it is, if i need it and how to hook it up. any ideas? thanks guys
Old Jun 19, 2010 | 02:19 PM
oreocreaming
.........nobody?
Old Jun 19, 2010 | 03:50 PM
94 smokin stroker's Avatar
94 smokin stroker
well oreo is that pump same model and type as the old pump if so i would say you dont have to have it
Old Jun 19, 2010 | 04:12 PM
oreocreaming
my old ip is on my 90, this one is a 94 or so it says. its a v belt though, so that makes me believe its older, or the previous owner switched everything to v belt cause thats what his original stuff was
Old Jun 19, 2010 | 04:44 PM
94 smokin stroker
well if you find out it is a real 94 pump i will go look on mine and try to find out more for you just let me know
Old Jun 19, 2010 | 05:21 PM
oreocreaming
I don't have one on mu 7.3l but my 6.9 has one that looks to be vacuum. I'm assuming it's a cold idle adjust cause the right side of the throttle shaft goes into it.
Old Jun 19, 2010 | 05:37 PM
greywynd's Avatar
greywynd
I can't really tell from the picture, is the the tranny control? (Forget the proper name.) With a C6 it would be vacuum, E40D electric, and not sure if there is anything there or what for standards, would have to go look at one to figure it out.
Old Jun 19, 2010 | 05:56 PM
oreocreaming
my 6.9 with the vacuum is a 4spd, my electric was a 5spd. Not sure if any swaps were made on them. I know my 90 with nothing on it is factory pump, factory engine and factory 5spd.
Old Jun 19, 2010 | 06:18 PM
94 smokin stroker
could be that makes sense it would be the high idle one way to find out is fire up the motor and see if it has high idle if not then thats what it was
Old Jun 19, 2010 | 06:29 PM
David85's Avatar
David85
Correct. Thats the FILP sensor (FIPL = Fuel Injector Pump Lever)
FIPL is ford speak for throttle position sensor.
But since oreo has a stick shift transmission he can ignore the sensor or toss it because its not needed on his truck
Old Jun 19, 2010 | 06:52 PM
94 smokin stroker
ok so that means mine has one cause its e40d
Old Jun 19, 2010 | 07:10 PM
oreocreaming
thanks dave. That's what I wanted to hear lol.
Old Jun 19, 2010 | 09:52 PM
greywynd's Avatar
greywynd
Glad you're around, it's a term that I can never remember!!
cuellar23
1961 - 1963 F100 Unibody
Apr 14, 2015 03:42 PM
oreocreaming
35
Oct 21, 2012 07:14 PM
oreocreaming
89
Apr 11, 2011 01:08 AM
oreocreaming
Nov 29, 2010 06:42 PM
oreocreaming
Sep 19, 2010 05:02 PM
