vacuum pump?
Old Jun 19, 2010 | 11:23 PM
poocher pup's Avatar
poocher pup
vacuum pump?
How can you test the belt driven vacuum pump without a gauge to see that it is making enough vacuum? This is on a '87 6.9l. Thanks in advance for any help.
Old Jun 19, 2010 | 11:52 PM
94 smokin stroker's Avatar
94 smokin stroker
well it is supposed to be bout 20 pounds if it doesent feel strong enough then you need a vacum pump they say you can also turn the vents on on the3 dash and if when you hit the brakes quick a few times it changes to defrost vents then its the pump but good way to tell is just test the suction on hand and see if it feels like 20 pounds could be booster to did you consider that here is a link to buy the pumps from http://pensacoladiesel.com/1983-1987...cuum-pump.html i know it is for the 7.3 but they are identical
Old Jun 19, 2010 | 11:54 PM
87crewdually's Avatar
87crewdually
Quick test in a pinch I do is pull the rubber hose off the pump and with the truck idling put your finger right on the pump barb. It should suck your finger quick and strong. If you have to hold it on there for 10 seconds to get any kind of suction, it's shot.
Old Jun 20, 2010 | 12:01 AM
94 smokin stroker
ya same thing i said i mean you can feel that much suction if you cant then somethins wrong
Faster71
Feb 19, 2014 04:43 AM
garrettsr5
May 15, 2013 04:09 PM
rugermack
Jul 25, 2008 09:13 PM
enduringexplorer
Sep 6, 2005 06:48 AM
sparke454
Aug 2, 2004 08:22 PM
