gauge problems
Old Jun 19, 2010 | 04:22 PM
dmeyer 351 4x4 rebel's Avatar
tried some more thing still none working is their a way to get one to work at a time?
Old Jun 19, 2010 | 04:39 PM
the dome lights stopped working to. when i have the high beams on the gauges light up but dont move ..
Old Jun 19, 2010 | 04:51 PM
danr1's Avatar
danr1
I been looking for one single issue that could stop all the gauges from working, small print is kinda hard read and takes time, gotta read it all with magnifying glass!
Anyway about the only thing could do it is a bad ground, did you check all the grounds.
How about the one right at the battery itself, smaller gauge black wire from the negative battery post to the inner fender, you replaced the battery, you sure its there and is clean and tight?
Old Jun 20, 2010 | 02:08 PM
yes but when i hooked it up the ground came undone from the neg batt cable but the gauges were stop before
Old Jun 21, 2010 | 07:50 PM
still none working
Old Jun 21, 2010 | 08:43 PM
danr1's Avatar
danr1
You need that ground from the battery to the fender, it may or may not have one from the motor to the cab, regardless it still needs that ground in place.
Make sure its there if not connect it and see if it helps.
Old Jun 22, 2010 | 11:18 AM
ya i hooked it back up but none i think im ****ed
Old Jun 29, 2010 | 11:12 PM
still in need of help
Old Jul 30, 2010 | 11:59 PM
put the turck on road yest day still need help hard to now how fast im going or gas level plz help thanks
Old Jul 31, 2010 | 12:06 AM
leavy20's Avatar
leavy20
Do you have another place were you can atleast borrow/buy the cluster?
Highboy74
80
Mar 19, 2013 10:16 AM
4realestate
Mar 28, 2012 08:54 PM
powerstrokin2005
Dec 22, 2004 06:47 PM
lombodml
Bronco II
Oct 29, 2003 09:25 AM
adbradley
Oct 2, 2002 04:45 PM
