Gauge Problems with a 91 Ford Explorer 4X4
Old May 21, 2002 | 11:05 AM
adbradley's Avatar
adbradley
Old Oct 1, 2002 | 10:55 PM
wayne30's Avatar
wayne30
91 Eddie Baurer 4X4 EXPLORER
I am having problems in two areas. Number One: My oil and temp gauges are reading high and they shouldn't. I changed the oil pressure sensor and the thermostat and they still read high. The oil pressure gauge goes up when I first start the truck. When I turn the lights on they read even higher. When I press on the brake they respond like the battery gauge does. Number two: The truck won't start sometime. I changed the starter, battery cable that goes to the starter and battery terminals. I had the battery tested at Pep Boys and they told me it was good. I tested the altenator by jumping it and then disconnecting the positive battery cable and it still ran. I turned the lights on while the positive terminal was disconnected and the truck still ran. Can someone please tell me what is going on. I am about to go crazy and broke at the sametime. I love the truck because it is a good truck and it is mine!
Old Oct 2, 2002 | 04:27 AM
Opera House Works's Avatar
Opera House Works
[updated:LAST EDITED ON 02-Oct-02 AT 05:28 AM (EST)]Run a new heavy gauge wire from the battery negative terminal to the frame/body. There is a voltage potential between the engine and the frame that develops when current is drawn. This should also happen when the headligts are turned on. If you have a good voltmeter you will probably see about 1/2 to 1 volt between engine and frame under load. Ground straps corrode over time or the engine was worked on and they forgot to put them back on.
Old Oct 2, 2002 | 04:45 PM
wayne30's Avatar
wayne30
I was thinking about that but, I didn't know if that would work and I didn't know that much in detail like you just told me.I am going to try that right now!
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
Offroad & 4x4
Dec 9, 2006 09:03 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
CustomCab4x4
Feb 3, 2002 02:20 PM
