Bronco II Ford Bronco II
Temp Gauge
Old Oct 28, 2003 | 11:10 PM
lombodml's Avatar
lombodml
Temp Gauge
I seem to have a problem with my Temp Gauge. Sometimes it works and sometimes it stays pegged at the bottom. Any suggestion?
1987 Bronco II 2.9L auto 4x4
Old Oct 29, 2003 | 07:56 AM
_rich_'s Avatar
_rich_
First, make sure that your cooling system is full. The gauge doesn't work well when it's in an air bubble.
Second, look at the sending unit to be sure that the connection is good. If you stand at the front of the truck and look at the thermostat housing (where the top radiator hose connects to the engine), the sending unit for the guage is just behind it to the right (driver's side) with a single wire.
The sending unit itself is probably only a few bucks if you have to replace it. Be sure you get the one for the gauge, not the one for the computer. It's possible that the gauge itself has a problem, but I can't offer much help there.
Old Oct 29, 2003 | 09:25 AM
lombodml's Avatar
lombodml
Thanks. I will try that.
fixit5561
Jun 29, 2010 06:18 PM
1995sho
Feb 25, 2008 05:08 PM
AKC24
Jan 23, 2008 09:48 PM
fishindave11
Bronco II
Jul 18, 2005 10:43 AM
Toonce
Aerostar
Jun 10, 2003 09:29 PM
