canister style oil filter
<HR style="COLOR: #d1d1e1; BACKGROUND-COLOR: #d1d1e1" SIZE=1 itxtvisited="1"><!-- / icon and title --><!-- message -->I posted this in the 534 thread but didn't get any response.
This is for my '62 Merc tilt-cab, M950 -I want to get this finished so that I can move the truck this weekend.
Doing the first oil change on the 534 and want to make sure I have the parts inside in the correct order. The new element came with new canister gasket and a washer seal. Is the metal washer on the outside of the canister anything special and should it be replaced.
Also: I did a search of the forum and could not find out what the correct order of spring/washer etc, inside the canister should be. When I took it apart and cleaned everything up it looked like the new washer seal should go on the hollow bolt first; then the spring with the steel bottom against the washer seal; then the element. Is this correct?
I don't want to put this back together only to find it leaking.
I have found alot of interesting info on this site so far. Thanks.
<!-- / message -->
<!-- / message -->
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtvisited="1"><!-- / icon and title --><!-- message -->I posted this in the 534 thread but didn't get any response.
<!-- / message -->
<!-- / message -->
I picked up a fram filter, in stock at our local auto parts warehouse.
Rob
Here's a few links for filter interchange.
Baldwin Filters E-Catalog
http://www.cumminsfiltration.com/cat...sreference=yes
http://www.napafilters.com/filterlookup/
blackjack33
05-12-2016 04:06 PM
uncompromise
12-03-2015 09:22 AM
