canister style oil filter
<HR style="COLOR: #d1d1e1; BACKGROUND-COLOR: #d1d1e1" SIZE=1 itxtvisited="1"><!-- / icon and title --><!-- message -->I posted this in the 534 thread but didn't get any response.
This is for my '62 Merc tilt-cab, M950 -I want to get this finished so that I can move the truck this weekend. Doing the first oil change on the 534 and want to make sure I have the parts inside in the correct order. The new element came with new canister gasket and a washer seal. Is the metal washer on the outside of the canister anything special and should it be replaced. Also: I did a search of the forum and could not find out what the correct order of spring/washer etc, inside the canister should be. When I took it apart and cleaned everything up it looked like the new washer seal should go on the hollow bolt first; then the spring with the steel bottom against the washer seal; then the element. Is this correct? I don't want to put this back together only to find it leaking. I have found alot of interesting info on this site so far. Thanks. <!-- / message --> |
Originally Posted by Rewindcat
(Post 9016138)
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtvisited="1"><!-- / icon and title --><!-- message -->I posted this in the 534 thread but didn't get any response.
Thanks, I can now finish this off.
Rob |
I'd rep Redcat, but can't "so soon"... Give him some points :-X22
C1TZ6731C .. Oil Filter-Cartridge Type (Motorcraft FL24) / Obsolete
Fits: 401/477/534 engines. Closest source to BC that has stock: WESTLIE FORD in Camas WA has TWO = 800-499-5122. |
Originally Posted by Krewat
(Post 9019257)
(Post 9036623)
Fits: 401/477/534 engines. Closest source to BC that has stock: WESTLIE FORD in Camas WA has TWO = 800-499-5122. I picked up a fram filter, in stock at our local auto parts warehouse. Rob |
Rob, you might want to make note of the number Bill supplied. Parts for some of the older stuff are getting harder to find. Also you might come across a deal on new old stock that can be had for pennies on the dollar. I've scored on a couple of these and did well.:)
Originally Posted by Redcat Diesel
(Post 9042504)
And places like NAPA can cross these #'s to make sure you get the right stuff. |
Here's a few links for filter interchange.
Baldwin Filters E-Catalog http://www.cumminsfiltration.com/cat...sreference=yes http://www.napafilters.com/filterlookup/ |
