My car engine won’t start
Old Jun 20, 2010 | 10:18 AM
69cj's Avatar
69cj
Try this link for all DTC's
http--www.dieseltalk.com-support-DTC.pdf
Old Jun 20, 2010 | 10:29 AM
npccpartsman's Avatar
npccpartsman
Originally Posted by Alrafee
Did those items (P0672 Glow plug #2 circuit failure<O
P0677 Glow plug #7 circuit failure) can
<O stop the engine to start?
Did you have any idea from where is smoke coming, does it indicate for something?
How the compression test can be done?
I'm not sure that two glowplugs can prevent the engine from starting but they can make it smoke and more difficult to start. Your post about diagnostics indicated a "Perform manual compression" so I'd ask if they indeed did that test and what the results were by cylinder. It should be in PSI or KPA. DON"T let them just say they did it but can't show you the results. That would throw up a BIG red flag in my book. A competent tech will have those numbers written down.
As far as the smoke goes, it could be that you have any number of cylinders trying to fire and the smoke is uncombusted diesel fuel. That is very difficult to say without seeing it or knowing the color of the smoke.
Can you say where the truck is being repaired? I see that you are from Saudi Arabia.
Old Jun 20, 2010 | 12:10 PM
cartmanea's Avatar
cartmanea
With the P0611 code, I would replace the FICM first and go from there. Maybe clean the EGR as well since that's easy.
donbrown
May 1, 2010 12:21 AM
mjpmn
Aug 10, 2008 05:50 PM
svenne1
Oct 17, 2007 11:23 PM
99-B-4000
1983 - 2012 Ranger & B-Series
Aug 11, 2007 07:42 AM
