Engine shake on cold start
Old Jul 19, 2007 | 09:31 AM
99-B-4000's Avatar
99-B-4000
For the past couple weeks on cold starts I would get what seems to be a engine shake or vibration. Once the engine idles down the shake goes away and does not occur when warmed. The IAC was changed recently.
Old Jul 20, 2007 | 06:27 AM
Rockledge's Avatar
Rockledge
Does this only happen after it sits overnight?
Old Jul 20, 2007 | 02:13 PM
99-B-4000's Avatar
99-B-4000
That's a yes to only overnight sitting. If it helps 103k and MAF was cleaned a month ago.
Old Jul 20, 2007 | 02:53 PM
Rockledge's Avatar
Rockledge
I would suspect some sort of leakdown. Maybe an injector is at fault, or you might have some bad gaskets allowing oil and/or coolant into the combustion chambers. Have you had to add any coolant lately?
Old Jul 21, 2007 | 02:58 PM
99-B-4000's Avatar
99-B-4000
No loss of the coolant lately, if it were an oil leakdown would'nt I be getting the blue puff of smoke on start-up. I had an old Chevy that did that. As a novice how would I detect leaking injector.
Old Jul 21, 2007 | 03:17 PM
Rockledge's Avatar
Rockledge
If you can get your hands on a fuel pressure tester you can measure the fuel pressure, and then see how long the system holds the proper pressure. If it bleeds down too soon, then that would support a leaky injector.
You also might try pulling the spark plugs and see what they look like.
Old Aug 6, 2007 | 10:44 AM
99-B-4000's Avatar
99-B-4000
After the last post my shake subsided for about a week and then three days ago CEL = cyclinder #3 misfire, one bad plug. I decided to check my maintanence records and, I realized I have had one plug go bad three different times. First at 51k, second at 70k, and now at 104k. On the previous times I can't remember a shake on start. I Have yet to change the plugs I was wondering whether I should try just changing #3 first or all of them.
Old Aug 6, 2007 | 11:36 AM
Rockledge's Avatar
Rockledge
How old are the plugs and wires?
IMO, you ought to have a used oil analysis done to determine if any coolant is getting into the oil. Inexpensive and very easy to do.
http://www.blackstone-labs.com/gas_engines.html
Old Aug 6, 2007 | 04:49 PM
99-B-4000's Avatar
99-B-4000
The plug are Autolite dbl plats (APP 103) are 3 years and have 34k on them. The wires were replaced in 05 and have 29k on them. Thanks for the link I'll check it out.
Old Aug 10, 2007 | 04:22 PM
99-B-4000's Avatar
99-B-4000
Today I replaced the #3 spark plug and all problems are gone. Now my question is should I have only replaced the one plug or go with the whole set. I hate the thought of only getting around 34k out of a $25 for a set of plugs.
Old Aug 11, 2007 | 07:42 AM
B-Aerostar's Avatar
B-Aerostar
Question
My 95 awd Aerostar does the same thing. I have to change #3 and #6 in everything is fine for about 3 - 4 weeks.
dpa_ford
1997 - 2003 F150
Mar 8, 2011 09:28 AM
rfrasure
Oct 19, 2010 09:00 PM
mikeski
13
Dec 25, 2006 08:14 PM
MTENIENTE
4 Cylinder Engines
Dec 7, 2005 08:31 AM
