Front fender support
Old Jun 17, 2010 | 10:21 AM
tip49's Avatar
tip49
Has anyone fastened their front fenders to the lower cab cowl, or would this limit movement; and cause stressing of the fenders ? I haven't bolted the fender to the running board as of yet.
I was looking at drilling through and bolting , mid point on the rear of the the fender.
Old Jun 17, 2010 | 11:03 AM
Tomget's Avatar
Tomget
tip49
I was wondering do you have one of these connecting panels at the bottom of your front fender? It connects your front fender/running board/lower cowl area. You should have one on each side. One for the passenger side and one for the drivers'.
Is it that the lower rear of your front fender is not stable enough? These little pieces are sometimes missing, and are available aftermarket. etc.
Or do you just want more support etc.
Tom
Old Jun 17, 2010 | 11:36 AM
Julies Cool F1's Avatar
Julies Cool F1
You don't want to attach any of the body parts rigidly to the cab. The cab is mounted on semi-flexible arms with rubber mounts. Also the frame of the trucks is built to be flexible. If you bolt up your fenders to the cab, it will torque and twist and cause quite a bit of damage to the fenders.
If you have the right fented welt installed, they should be fairly snug up next to the cowl.
Here is another picture of the panel Tom has pictured above, but installed on the running board. The two outward facing holes bolt to the fender and pull it in:
Name:  D2 Front Fender Extension Panel Installed.jpg
Old Jun 17, 2010 | 12:34 PM
tip49's Avatar
tip49
OK
Thanks for the input; I will install the running board to fender brackets, and leave well enough alone.
Thanks again.
400inatruck
Sep 9, 2012 09:26 PM
arrowheadfred
Dec 14, 2010 05:59 PM
54truck
15
Mar 15, 2009 11:14 AM
DR Smith
Feb 12, 2008 12:04 AM
nsaikia
17
Apr 9, 2007 09:34 AM
