fitting front fenders
Old Mar 15, 2009 | 05:58 AM
54truck's Avatar
54truck
on my 54 f100 i want to fit my front fenders. Where they bolt to the cab just woundering can you get a threaded insert that goes in the holes on the cab?? or is it just nuts and bolts that hold the fenders in place?? thanks
Old Mar 15, 2009 | 09:00 AM
56panelford's Avatar
56panelford
Just nuts and bolts
Old Mar 15, 2009 | 09:10 AM
54truck's Avatar
54truck
ok thanks,also the hole at the bottom of the fender where it bolts to the cab looks like it's gonna be realy hard to get a nut on a bolt as it's right at the bottom of the cab corner is there and easy way of getting to it?? cheers for your help
Old Mar 15, 2009 | 09:32 AM
56panelford
I have a 56 and I'm not sure if the 54 has the inspection plate at the bottom of the cowl, there is a reinforcement bracket that is behind the cowl that has a bolt that is welded to it for fastening the fender. If you don't have a copy of a catalog of aftermarket parts go to www.midfifty.com and seach the parts, it shows how things fit together and what is all available, hope this is of some help.
John
Old Mar 15, 2009 | 09:35 AM
56panelford
Page 94 of midfiftys catalog shows the part I'm talking about
Old Mar 15, 2009 | 09:45 AM
54truck's Avatar
54truck
no mine does'nt have an inspection plate it's all blanked off. does anyone have a picture of this area so i know what it's suppose to look like?? thanks
Old Mar 15, 2009 | 09:59 AM
56panelford
It's that grey triangular hole at the bottom of the cowl
Old Mar 15, 2009 | 10:01 AM
54truck's Avatar
54truck
ok are you talking about the inner fender to lower cab mounting angle?? is so how does it work?? it's doesnt realy say in the catalogue. cheers
Old Mar 15, 2009 | 10:07 AM
54truck's Avatar
54truck
ok thanks for the picture great help does that triangle hole stay open or does some sort of cover go over it?? to stop the water from getting trapped cheers
Old Mar 15, 2009 | 10:13 AM
56panelford
The inspection hole is that triangle shaped hole a the bottom of the cowl towards the front, the fender brace I'm refering to is behind the cowl and was spot welded in where you see the grinded areas on the cowl. You will see this brace from inside the cab if the kick panel is removed.
Old Mar 15, 2009 | 10:16 AM
56panelford
There is a cover that is held on with a self tapping screw top and bottom, you could cut this hole in yours and make your own plates to cover the holes.
Old Mar 15, 2009 | 10:30 AM
cmoritz's Avatar
cmoritz
I think things are a little different on the 53-55 models...
Inside the inner cowl is a strip that is welded to the cowl panel,..it has ( If memory serves me correctly) 3 holes for mounting the fender(using nuts/bolts..easy to get to), but at the bottom of the strip..a nut is welded, on something close to a 45 deg, which the lower fender bolt will go thru. Without that nut in place, installing a nut/washer/bolt combo would be tricky because it is such a tight space at that part of the cowl, also, your nut/bolt combo would have to be angled to meet the lower curve,which leaves you with " large flat washers" , against 2 "curved" areas of contact,...the curved fender and the curved cowl.
If your past the point of installing the support strip with the attached nut, you may end up with the fltwasher/curved panel fit..but it will be tight.
Most of these old trucks i"ve seen, started rustiing at this spot..and the immediate fix was just that..kind of a "field-fix" Lol! Hope this helps, Good Luck!
Old Mar 15, 2009 | 10:36 AM
cmoritz's Avatar
cmoritz
Thats a great idea on adding the access panel John,..I had thought about it a couple of times myself , just as a " helpful hint" ..or "try this if you can"t get to that" alternative.
I installed the strip with the nut , and just kept moving..Thank"s ! That idea will help someone!'''
Old Mar 15, 2009 | 10:41 AM
54truck's Avatar
54truck
i think im gonna cut a hole in the cowl as the picture. because im not gonna be able to get my hand down the inside of the cowl and manage to get a nut on a bolt. cheers
Old Mar 15, 2009 | 10:56 AM
56panelford
54, you should have a nut that is already there if it isn't rusted away,I'm sure that the Ford engineers decided to put that inspection hole there because of the rust problem. Another problem that occured after was the dirt and sand would get behind this inspection hole plate and fill the bottom of the cowl and creat another reason for rust to start, moist mud, so you need to clean this area out once in a while. I plan on putting a sealer around the edges of mine.
