Sponsored by: Real Truck
4X4, Hubs, seals, differences, ect
Old Jun 18, 2010 | 02:31 AM
brian42's Avatar
brian42
Veteran: Navy
Every time I tear down something (especially if it has to do with the knuckle), I ALWAYS replace EVERY seal. The few extra dollars go a long way if the seal looks "good" but craps out or gets damaged during removal/re-install.
Just my .02
Old Jun 18, 2010 | 07:50 AM
bakon's Avatar
bakon
Back together and works.
Also changed solenoid on right fender. Just looked worn, connections and electrical connection was worn and corroded.
Locks up good and I can hear the switch in the hub area when the switch in the dash is turned.
Old Jun 18, 2010 | 10:00 AM
rodneyf10's Avatar
rodneyf10
Help! Tore my hubs apart before reading thread. I know, stupid. Pryed selector **** off hub and broke the ears off. Ford says no parts available to replace parts I broke. Looks like I must buy new hubs. What are my options.
Old Jun 18, 2010 | 11:16 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
For the cost, Warn or Mile Marker manual hubs are the way to go - the only thing is, you need to get out and lock them when you want 4x4
Old Jun 18, 2010 | 02:40 PM
bakon's Avatar
bakon
I found this on eaby and contacted the seller. He has two and would sell them both for $350 including shipping. (The buy it now was $239 for one)
I know the warn or milemarkers are cheaper but reported to be heavy duty.
I wanted to retain the 4x4 auto/manual mode I have paid for in the truck. Dont know the seller but we did email a few times. Said they are complete hubs. I got one locally for $238
FORD F-250 F-350 F450 & EXCURSION 4X4 AUTO LOCKING HUB : eBay Motors (item 220620744077 end time Jun-18-10 16:05:42 PDT)
Old Jun 18, 2010 | 02:55 PM
krewat's Avatar
krewat
I would find out what Part's Guy Ed wants ...
Old Jun 18, 2010 | 03:36 PM
krewat's Avatar
krewat
Ed says "$213 each". Plus shipping, I'm assuming.
Old Jun 18, 2010 | 05:35 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
yeppers
Old Jun 19, 2010 | 07:11 AM
rodneyf10's Avatar
rodneyf10
Thanks for the info.
Going aftermarket. Which hub is best the Warn or Mile Marker or Superwinch or Rugged Ridge? Are there any evaluations or reviews out there?
Are there any special instructions, replacing the factory hubs with aftermarket.
Old Jun 19, 2010 | 09:29 AM
bakon's Avatar
bakon
With the right part they go right on from the threads in here. some disconnect the vacuum line at the wheel, some at the solenoid.
Guy I spoke to here did not disconnect and had no problems. He had the Warn Supreme model. His only complaint was the finish was peeling (4 years old). It was the gold colored handle, looked like a clear coat was peeling off.
He also said the AUTO/Manual stock hubs locked up on the spot where his Warn took a few turns of the wheel once engaged manually. He said he preffered the stock set up for the winter. He did not need to keep them locked for the "just in case" he needed it. Just his opinion, I would just lock them once stuck or before a snow covered hill (which is everywhere in Pittsburgh).
Old Jun 20, 2010 | 05:45 PM
rodneyf10's Avatar
rodneyf10
thanks for help
Old Jun 21, 2010 | 02:05 PM
bakon's Avatar
bakon
Got the bill today. $465.oo $315 in parts and $150 labor. I feel I did extremely good.
A/C drain and recharge
Front axle fluid change
Transfer case change
Tranny flush
No charge
Front o rings (I paid for seals), 1 new hub and 4x4 soleniod were parts. Labor for front axle work only. This was same mechanic who said 9 hours book time to do the work. Buddy of father in law, now mine too.
Spitfire0450
Jan 28, 2016 12:46 AM
Fastback460
Nov 29, 2014 05:13 AM
Enduroman
Dec 6, 2013 02:53 PM
gordo2
Offroad & 4x4
15
Mar 29, 2010 10:09 AM
fteduran
Sep 1, 2009 01:19 PM
