TTB axle
Old Jun 14, 2010 | 05:55 PM
mabc926's Avatar
mabc926
TTB axle
I know this isn't anything to do with diesel but you guys know a lot so I'll just ask you.
I might have a chance to get some 37" hmmwv tires on beadlocks what I want to know is would the 37's just tear my TTB apart til I can swap the dana 60 under it?
Old Jun 14, 2010 | 06:09 PM
peruses's Avatar
peruses
dana 44 ttb?
Old Jun 14, 2010 | 06:10 PM
peruses's Avatar
peruses
and what do you do with the truck?
Old Jun 14, 2010 | 06:13 PM
mabc926's Avatar
mabc926
I'm guessing it's a 44 cause the rear end is a stering 10.25....and it will just be a all around work truck....only really want the beadlocks so I can change tires my self.
Old Jun 14, 2010 | 06:33 PM
peruses's Avatar
peruses
if you aren't plowing or rock hopping in it the ttb should live while you save up for a dana 60 swap
if you don't need the beedlocks though the handtools for changing tires are probably cheaper than getting the hummer rims recentered to fit on our axles properly (them things have a crazy offset changin them by hand is a bit of a pain but I've done it on g'pa's farm truck
Old Jun 14, 2010 | 06:43 PM
joe f350's Avatar
joe f350
i dont trust a ttb as far as i can trow one
Old Jun 14, 2010 | 07:00 PM
mabc926's Avatar
mabc926
I don't need the beadlocks...they just look cool lol but yeah I just looked at the offset on the rims I have now and the off set on the hmmwv rims....looks like I'd need a freaking 3 inch spacer!...screw that.....only reason I'm looking at the hmmwv tires is cause they're cheaper than the bfg's I've seen....damn 16.5 rims!
Old Jun 14, 2010 | 08:50 PM
Coalroller's Avatar
Coalroller
best bet is to go back to a 16" rim or 17" more rim choices available same with tires, that way you can get a rim and tire package thatll not only look good on the truck but will do what you need them to do with modin stuff up with spaces and such
Old Jun 14, 2010 | 09:47 PM
David85's Avatar
David85
Slide under the truck and look up at the bottom of the pumpkin on the front end. If its a Dana44, it should have a "44" cast into the bottom of the differential case. If its a Dana50, it will show a "50".
Old Jun 15, 2010 | 01:04 PM
RCrawler's Avatar
RCrawler
Dana 44 has a 3.5" diameter locking hub
Dana 50 is 4.0"
Jason
Old Jun 15, 2010 | 03:46 PM
peruses's Avatar
peruses
word on here is the dana 50 is pretty stout I have one and have decided not to worry about it till I kill it
Old Jun 15, 2010 | 04:01 PM
mabc926's Avatar
mabc926
Well I'm not getting the hmmwv tires....can't get a pair was going to get them from am general but no dice.....could get some off ebay but I don't want to have shipping and all that crap......guess I'll be sticking with the bfg's, I'd get 17" rims but I like my 16.5's, and the dana 60 swap is just for tire wear.
Old Jun 15, 2010 | 04:04 PM
joe f350's Avatar
joe f350
most licky u have a dana 44 most dana 44 in 1500 and f150 wont stand up to a 37 inch tirse and they dind have a 900 plus pound motor
Old Jun 15, 2010 | 08:15 PM
Dave Sponaugle's Avatar
Dave Sponaugle
85 regular cab F250, most likely a Dana 44
85 extended or crew cab F250, most likely a Dana 50.
Old Jun 15, 2010 | 08:23 PM
94 smokin stroker's Avatar
94 smokin stroker
mines a 94 7.3idi regular cab and it has a ttb dana 50 factory axle im gunna do a swap but the 50 is preety dang stout im runnin 33in bfgoodwrench mud terrains on 20 in mickeys and it rides like a 2 horse wagon cause of the mud terrains but the axle can handle them easy
1990f150kid
50
Jul 27, 2015 09:43 PM
RedDevil460
38
Feb 24, 2013 09:32 PM
04yfzkid
41
Mar 27, 2011 06:58 PM
86sixbanger
Offroad & 4x4
38
Jul 13, 2010 01:59 PM
cek181
19
Dec 11, 2002 04:28 PM
