Modular V10 (6.8l)
Thorley Header Install
Old Jun 15, 2010 | 09:58 PM
  #31
Johnny Langton's Avatar
Johnny Langton
Originally Posted by HB76
Ok smart one tell me just how does the eecu know which cylinders its reading the exh from... If you want a true closed loop you would need a sensor on each cylinder...
That ain't going to happen. Plus each injector isn't adjusted to the oxy sensor each time it fires... You are giving them way to much credit. Its just a half *** closed loop system, it could care less how many cylinders its testing.
Plus if its testing 5 cylinders and 4 are ok the other one would have to be way off to over ride what the others are putting out... Or two could be way on the lean side and two just right so that would mean one could be way rich and still be in specks....
Just something for you desk top mechanics to think about before you come out to the real world...
The PCM knows how much O2 should be in the exhaust stream at a given air/fuel ratio,and knows if a single cylinder is lean/rich based on when that cylinder's spark plug fires and the transport delay from the spark plug being fired til the exhaust should be at the O2 sensor. It gets far more complicated than that,but it should suffice to say that the PCM can control air/fuel of a single cylinder based on O2 input,so accurate measurements of the O2 in the exhaust are vital for a properly running engine that will operate at peak efficiency.
JL
Old Jun 16, 2010 | 07:10 AM
  #32
krewat's Avatar
krewat
FTE Leadership Emeritus
Not to mention that 3 cylinders are never going to provide an even stream of exhaust - dead spots occur, and what does the PCM see at the O2 sensor?
Old Jun 16, 2010 | 07:11 AM
  #33
krewat's Avatar
krewat
If you think JL (or anyone else here) are "desktop mechanics" you haven't been here very long, have you?
Old Aug 24, 2010 | 01:13 PM
  #34
fomoco6.8's Avatar
fomoco6.8
Ex03AK..... Hi Stew, check your PM's. Thanks
Mike
Old Aug 24, 2010 | 10:34 PM
  #35
Pinky Demon's Avatar
Pinky Demon
I have the same setup, and I'm not worried about the closed loop being off because of not catching a sniff of every cylinder. It wont know which ones its checking anyway... Only time it would make a big deal is if a injector or plug went bad, then you'd hear a miss anyway.
Carburetors worked just fine for years till EPA got their noses into everything... And we don't have no smog sniffers around here to check on us anyway
And know we all know to disregard everything you post after this. Thanks for the heads up.
Old Aug 24, 2010 | 10:40 PM
  #36
HB76's Avatar
HB76
Well I've been running my headers with it not knowing what all the cylinders are doing and it hasn't blown up or burnt down yet.... Maybe I'm right and you are over rating the close loop system...
ak-angler
Modular V10 (6.8l)
302
Nov 25, 2023 02:39 AM
FordCamping
Modular V10 (6.8l)
53
Jan 18, 2017 06:51 AM
Brentmez45
2009 - 2014 F150
Nov 5, 2016 05:02 PM
jagrote
17
May 29, 2016 11:46 AM
AAubinoe
Jun 13, 2015 08:29 AM
