update with video
Old Jun 9, 2010 | 10:44 PM
joe f350's Avatar
joe f350
update with video
YouTube - battery cabels on
Old Jun 9, 2010 | 10:56 PM
swooshcmk's Avatar
swooshcmk
I'm most certain your wires on the alternator are the issue. your sig says an 85 which should be a voltage regulator separate from the alternator. If you don't have the voltage regulator hooked up to the alternator to tell it to charge it won't charge. Looks like a new voltage regulator in the fender well I think.
Sometimes you can make out an F and and S label on the alternator for Field and Stator. F and S should connect to the voltage regulator F and S respectively. I've only got a gasser diagram to look at for the moment, but I'm assuming ford used the same wire colors.
I on the voltage regulator should be connected to a light green with red tracer that connects to the instrument cluster for the charging warning light.
S on the voltage regulator connected to S on the alternator and is white with a black tracer
Field from voltage regulator to the alternator is orange with a light blue tracer.
Old Jun 9, 2010 | 11:00 PM
joe f350's Avatar
joe f350
ya i have replace the reqular i think the wires plug in to the top alternator i need to know what wire go where
Old Jun 9, 2010 | 11:05 PM
swooshcmk's Avatar
swooshcmk
I'll let you know in a few lol
Old Jun 9, 2010 | 11:07 PM
joe f350's Avatar
joe f350
thx
i have replaced sice it started droping batterys
2 alternator
volter reqalotor
2 batterys
all fuses
battery cables
Old Jun 9, 2010 | 11:11 PM
swooshcmk's Avatar
swooshcmk
My '85 alternator has an orange wire with blue tracer hooked up to the Field terminal. The field terminal is the one on the pulley side of the alternator. I have no wire connected to the stator of mine. hooking up the field will energize the alternator. You can jumper 12v to that field terminal of the alternator to do a "full field" test. This will cause the alternator to go full output so only do it for a short bit but can be useful to test the alternator. The regulator activates the alternator by energizing the field coils. Oh and the labels are on the back of the alternator as well for reference.
Stator terminal should be un-needed.
Best of luck!
I switched mine to a 200A internally regulated alternator
Old Jun 9, 2010 | 11:16 PM
joe f350's Avatar
joe f350
pic plz if u can kind sure
Old Jun 9, 2010 | 11:31 PM
swooshcmk's Avatar
swooshcmk
Here ya go!
<img src="http://www.airplanesathome.com/FTEpics/Alt1.JPG" width="640">
<img src="http://www.airplanesathome.com/FTEpics/Alt2.JPG" width="640">
Old Jun 10, 2010 | 12:31 AM
oreocreaming's Avatar
oreocreaming
OR if you want, you can take it to a place that rebuilds alternators and have them convert it to a 1 wire. so that plug on top wont be used. just the one bolted to the rear. basically like older cars have. cost $25 when i did it to my chevy.
Old Jun 10, 2010 | 08:57 AM
87crewdually's Avatar
87crewdually
Your chevy alt is internally regulated so you can do that one wire conversion. The ford needs the orange wire to the regulator to excite the field to make a charge.
Old Jun 10, 2010 | 07:58 PM
peruses's Avatar
peruses
externaly regulated alts have some advantages too
like you can build a feild welder out of one if you're handy with electronics
Old Jun 11, 2010 | 12:35 AM
87crewdually
Yes this is true as I have one. And your correct it is recommended to use the ford style external regulated for this as you are able to full field it to the peak desired amperage at a moderate rpm.
Old Jun 11, 2010 | 12:44 AM
93_F250's Avatar
93_F250
Nice HFT die grinder....
Old Jun 11, 2010 | 05:42 AM
swooshcmk's Avatar
swooshcmk
Close... it's actually a harbor freight 220v spot welder My truck is getting new cab corners, outer floor pans, rocker panels, lower door skins and a fair amount of other repair parts fabricated from scratch and hoping I can make some use of it on the truck. Purchased the spot welder to make my life easier for fabricating the one-of-a-kind furnace plenum from hell when I added central air to the house. I figured it was a low enough use item that a HFT item should suffice. If it's a tool I know I'll get a lot of use out of or quality will be an issue for usability I get a name brand proven product. Sucky part is you need clean tip to metal and metal to metal contact with the spot welder and all the body repair panels are painted and it insulates it enough to not want to spot weld...doh!
VONxRUBENxLA
Oct 9, 2011 08:12 PM
Kwikkordead
21
Jan 18, 2011 07:38 AM
OutlawNomad
Mar 19, 2010 04:15 PM
jimbo beam
General Automotive Discussion
Jan 28, 2009 08:44 PM
