Intake Mod, V3.0
Old Jun 10, 2010 | 10:26 PM
  #31
LCAM-01XA's Avatar
LCAM-01XA
Using Dave's numbers, a 6.9 running at 3300 rpms pulls in abit over 400 cubic feet per minute, so if that blower can deliver more than 400 cfm there will be a benefit. Now the question is, is there an electric fan or something that can move 400 cfm and is small enough to be installed in the engine bay?
Old Jun 10, 2010 | 10:47 PM
  #32
joe f350's Avatar
joe f350
i will try it but how redneck is it lol
Old Jun 10, 2010 | 11:24 PM
  #33
wreckinball's Avatar
wreckinball
Wow, yeah it will be really redneck. Lmao. Powering it will be the only issue. Maybe if you had a 300 amp alternator and an inverter.
Dave, is it A) possible to benefit from an intercooler with a nonturbo setup and B) even able to work?
Old Jun 10, 2010 | 11:25 PM
  #34
oreocreaming's Avatar
oreocreaming
i never took any pics of all the piping. just these pics here. turbo clocked and the intercooler as it went in. sorry for the mostly night pics, i do my best work when the sun goes down. especially with the 110 degree days. i'll post pics of all the tubes ran tomorrow.
Old Jun 10, 2010 | 11:27 PM
  #35
oreocreaming
the pics of the holds were temp. they got cleaned up and finish welded. that was just under construction pics. right side is bolted in so it can be removed, pull out one side of the intercooler then rotate it upward to get the other side out.
Old Jun 10, 2010 | 11:32 PM
  #36
oreocreaming
finished product with the 37's.
Old Jun 11, 2010 | 12:56 PM
  #37
oreocreaming
heres the pics under the hood...
Old Jun 12, 2010 | 05:45 AM
  #38
RCrawler's Avatar
RCrawler
Need to do the cutout mod on the bumper or get a 95-97 bumper. Doesn't look like you're getting near the air flow you could be across the IC.
Jason
Old Jun 12, 2010 | 08:05 AM
  #39
LCAM-01XA's Avatar
LCAM-01XA
Agreed, that bumper does look like it covers a decent area of the intercooler.
Old Jun 12, 2010 | 08:32 AM
  #40
Coalroller's Avatar
Coalroller
oreo did you do all the bending of the IC tubing yourself or have it made at a shop?
P.S. looks great! i do agree with RCrawler and LCAM-01XA
Old Jun 12, 2010 | 10:20 AM
  #41
oreocreaming
ya I know. Finding a holie bumper aroun here is next to impossible. It will cme one day. Til then..... The charge doesn't boost enough to need more the it gets. And I had it bent. Had it done while I was having my exhaust work done. I can't afford a bbender worth a crap.
Old Jun 12, 2010 | 12:32 PM
  #42
LCAM-01XA's Avatar
LCAM-01XA
You can cut the bumper yourself, there was someone on here who did it to a bricknose bumper not too long ago, maybe a month or so?
Old Jun 12, 2010 | 12:34 PM
  #43
oreocreaming
ya, lmc has the plastic insert and i can go off that.... i like the look. maybe after i get my new engine built and start putting out some real boost.
Old Jun 12, 2010 | 05:28 PM
  #44
David85's Avatar
David85
Yikes thats a big intercooler! I wonder if you will even notice a difference with half of it blocked off. Could also make a bumper from scratch but modding or just swapping would be easier.
Doubt I could fit an intercooler of that size in my truck. Dual tranny coolers and the AC radiator already take up a lot of space. Maybe a custom grille of some sort but I still would have my doubts.
Old Jun 12, 2010 | 07:32 PM
  #45
mechelement's Avatar
mechelement
wreckinball, looks like a clean install with the detail paint job and all.
Damn Oreo that looks like a LOT of work went into that. Too bad your motor puked on you. Are you throwing a 6.9L in there this time around?
As far as the holes in the bumper... could you just drill out a pattern in that one to keep the stock looking one?
I've seen those turbos completely suck those flex ducts closed from a clogged filter on a PSD.
Dave, what did you use for your install? HVAC duct sheet metal? Did you notice a difference compared to the stock setup?
