Speedometer gear?
Old Jun 9, 2010 | 11:18 AM
DutchmanAZ's Avatar
DutchmanAZ
Speedometer gear?
Hi all.
Have a '76 F150 4x4 with what I believe is a NP435 transmission. I would like to get the speedometer working and have no clue of the tooth count for the required gear (gear is missing). Any ideas on how to determine which gear I need?
I'm plan on driving the truck from AZ to Washington state here in a couple of weeks and don't want any speeding tickets.
Thanks in advance!
Old Jun 9, 2010 | 01:25 PM
bucks77ford's Avatar
bucks77ford
Are you looking for the gear that attaches to the end of the speedo cable or the gear inside the transmission?
What is the rear end gear ratio and tire size?
There is a formula to calculate.
http://www.bgsoflex.com/speedo1.html
Old Jun 9, 2010 | 01:26 PM
DutchmanAZ's Avatar
DutchmanAZ
The gear that attaches to the cable. Thx
Old Jun 9, 2010 | 01:30 PM
bucks77ford
I edited my last post before you did. See above. If you have the other info we can get you the right gear.
Old Jun 9, 2010 | 01:37 PM
DutchmanAZ's Avatar
DutchmanAZ
31 inch tires, 3.50 rear end. Thanks for the link, but I'm unsure of the number of speedometer revolutions per mile.
Old Jun 9, 2010 | 01:48 PM
bucks77ford
The revs per mile usually is defaulted to 1000 referring to the odometer. Also, I think the Drive gear in the transmission is a 7 tooth, but correct me if I'm wrong. If its a 7 tooth Drive gear than based on the formula and the info given, you should need a 16 tooth driven gear.
http://www.bgsoflex.com/cgi-bin/spee...en&givengear=7
Old Jun 9, 2010 | 02:10 PM
DutchmanAZ's Avatar
DutchmanAZ
That should do it. Thanks!
JacobRM
19
Jun 3, 2014 06:35 PM
purecty
Sep 17, 2011 05:09 AM
schaad25
Apr 15, 2007 11:03 PM
Yogis1097
Jul 19, 2006 06:38 PM
