power steering pump
Old Jun 6, 2010 | 09:09 PM
Jayme Duty's Avatar
Jayme Duty
power steering pump
Came home after being gone for a week and there is a puddle of PSF on the ground under the truck. Checked the pump, sure enough it is empty. I have a donner pump out of a 91 ford bronco that has a 5.0 gasser. Will this pump fit on my 7.3L. It is about 15 miles away so i was hopping somebody would know before i go take it off and try the swap to figure out it don't fit and then start all over again
Old Jun 6, 2010 | 10:18 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Probably just have to swap the mounting bracket.
Ford used about the same power steering pump for a good many years on the trucks.
Old Jun 6, 2010 | 10:30 PM
LCAM-01XA's Avatar
LCAM-01XA
Pump is identical, brackets are likely different, pulleys are definitely different. Rent a pulley remover/installer tool from a parts store and the job will be a breeze.
feditmy
Jan 24, 2015 09:15 PM
helifixer
Jun 29, 2013 05:29 AM
derek0525
13
Jul 8, 2012 09:56 PM
BIG-DADDY-F350
Dec 22, 2011 11:24 PM
88PONY
Oct 30, 2009 07:56 PM
