Pre pump fuel filter
Old Jul 7, 2012 | 02:57 PM
derek0525's Avatar
derek0525
Trying to figure out what all I will need for a pre pump fuel filter part numbers fittings and stuff.
Old Jul 7, 2012 | 05:35 PM
timmyboy76's Avatar
timmyboy76
Welcome to guzzle's In-tank Hutch Mod Web Page
Old Jul 7, 2012 | 08:45 PM
dn29626's Avatar
dn29626
For the filter i use the wix 33007 which is for diesel fuel.
Old Jul 7, 2012 | 09:30 PM
rufushusky's Avatar
rufushusky
Well there are a lot of options for pre-pump filters... Everything from strainers, to spins to big marine fuel filters. What are you looking for?
Old Jul 7, 2012 | 09:50 PM
derek0525's Avatar
derek0525
Just the basic spin on fuel filter last time I changed my stock filter there was what looked like sand and black crud in the bottom of the fuel bowl. I know it's not going into the injectors because of the stock filter but wouldn't think it would be good for the fuel pump. I have looked at the kits you can buy but figured I could make one cheaper since I get the fleet discount at Carquest.
Old Jul 7, 2012 | 09:59 PM
rufushusky's Avatar
rufushusky
I would imagine car quest would have a cross reference for the base listed below...
Wix 24770 & Napa 4770 Base: FleetFilter Secure Online Store
Takes a 1-14 filter... Very common filter.
Old Jul 7, 2012 | 10:50 PM
Bonanza35's Avatar
Bonanza35
You can use the baldwin base #FB1311 and baldwin filter #BF1212. Or NAPA filter FIL3405 with NAPA base #FIL4770. There's lots out there, but these are good 2 mic filters.
Chet
Old Jul 7, 2012 | 11:59 PM
Crewcab Turbo's Avatar
Crewcab Turbo
I use Napa's filter FIL3405 and their base is a FIL4770.
Old Jul 8, 2012 | 01:30 AM
derek0525's Avatar
derek0525
Thanks I will have them cross reference all that stuff Monday. I'm guessing it's 3/8 hose that I need to get also?
Old Jul 8, 2012 | 09:41 AM
timmyboy76's Avatar
timmyboy76
yup, 3/8 hose for stock hardline replacement, going to the factory pump. Like me, i went ahead and cut the ends off the hardline and left it there, attached to frame, since it looked like a PITA to remove and also, it wasnt in the way of the new 3/8 line.
Chet, i would think, a 2 micron pre-pump set-up, without a lift/helper pump, would kill the factory pump?
Old Jul 8, 2012 | 11:34 AM
GonzoCSU's Avatar
GonzoCSU
https://www.ford-trucks.com/forums/9...er-bf1212.html
Old Jul 8, 2012 | 03:41 PM
rufushusky's Avatar
rufushusky
The BF1212 is 4 microns nominal and 20 microns absolute (98.6%)...it is the baldwin cross to an FG FS1212...commonly a suction side WS. You will have no problem.
PF7977 really is a GREAT fuel filter.... Other filter data too... - Dodge Cummins Diesel Forum
and...
info on page six..
http://shop.strictlydiesel.com/other...-Manual-v2.pdf
got the same numbers from baldwin.
Old Jul 8, 2012 | 08:33 PM
dn29626's Avatar
dn29626
Do not get too caught up in the small micron rating. Fuel filters clog prematurely when the rating gets really small. With the first filter you are really after chunks/trash. The downstream filters will get the rest.
Old Jul 8, 2012 | 09:56 PM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Also commonly used, 10 micron pre pump, and 2 micron post pump.
Shadowrider123
20
Nov 14, 2023 08:48 AM
D.J
Jan 16, 2008 05:46 PM
dyoungen
Oct 4, 2006 11:59 PM
frigerator
Apr 18, 2004 11:09 AM
GeneStoner
Jan 13, 2003 07:22 PM
