Sponsored by: Real Truck
POWER STEERING PUMP FAILURE
Old Dec 22, 2011 | 05:08 PM
BIG-DADDY-F350's Avatar
BIG-DADDY-F350
Short story; Early 99 F-350 power steering pump failed, replaced pump and and hydroboost hose. Problem is it is leaking at the compression fitting on the output side ( high pressure ) of the pump. I tightened it to the point I was afraid of damaging it. I then backed it out and used the provided O ring. That did no good. In my experience, you usually dont use teflon tape on the threads of a compression fitting. Could the remanufactured pump be the problem? Anyone have a similar problem? I need to try something to get the leaking stopped.
Old Dec 22, 2011 | 08:01 PM
redford's Avatar
redford
FTE Leadership Emeritus
Could it be the fitting?
Old Dec 22, 2011 | 09:16 PM
PA-Mark's Avatar
PA-Mark
check the sealing surfaces of both the fitting and the pump for a deep scratch, in my previous experience with these fittings, during maintenance, if the fitting gets dropped or knocked around it can get some dammage that wont allow it to seal properly.
and its possible to have cross threaded it on the way in... I have done this before... Boo!
its a long shot but give em a look-see, Mark
Old Dec 22, 2011 | 11:24 PM
BIG-DADDY-F350
Thanks for the feedback. I know what I'll be doing on Christmas eve.
1949f1
Nov 7, 2017 03:38 AM
Deerfield411
Dec 13, 2016 08:29 AM
Alvarez1112
Oct 17, 2010 01:36 PM
welder79
16
Mar 30, 2009 08:43 AM
big_witt7
Mar 24, 2009 07:43 PM
