AC Problems
Old Jun 5, 2010 | 11:08 PM
Chance_Thomas's Avatar
Chance_Thomas
AC Problems
I noticed my AC acting little weird. I checked and I was 2 cans low. Added those everything seemed to be fine. In the last few days it seems it take a while for the compressor to kick on.Someone was telling me about about replacing a relay on the compressor...any thoughts? If anyone has the part number that would be awesome.
Old Jun 5, 2010 | 11:34 PM
van_350sd's Avatar
van_350sd
One way to check the compressor is to remove the orifice tube and check the screen in it. If it has small metal filings in it that tells you the Compressor is a bout to croak.
If the orifice tube only has a little sediment in it and no metal (Fine metal) filings, just replace the tube then fill it up again.
The only way to check the tube is to remove the 134A.
It's kinda worth it to check because if you do find the screen is filled (one one end Mostly) with the metal filings it's time to install a new Compressor.
Go to Rockauto dot com to check all the parts in the AC system, it will show you 10 different orifice tubes etc.
But if you want to buy the parts, Ed the parts guy gent here would love your business.
Best,
Russ
ps. I just use rockauto for the great reference and to get part numbers.
Old Jun 5, 2010 | 11:42 PM
rbaker6336's Avatar
rbaker6336
Have you done the bump test?
When the compressor won't kick on bump the clutch hub with a hammer handle
Old Jun 6, 2010 | 07:38 PM
Chance_Thomas
It's working today without any issues. I was reading on a few past articles really sounds like maybe it might be air gap. Does anyone have the pics to remove the shimms?
Old Jun 6, 2010 | 08:33 PM
big poppa's Avatar
big poppa
Did you test on the low side connection and where would that be??? I noticed today my air vent temp. was about 60* and it was about 75* and humid, just didn't seem cold as it should.
marcogyver
Sep 10, 2016 08:33 PM
trobin002
1997 - 2003 F150
Mar 19, 2015 09:29 AM
sitdown318
General Automotive Discussion
May 11, 2014 09:10 PM
seesaw_4
Mar 9, 2008 11:20 PM
txzaphod
Aerostar
Nov 10, 2003 08:06 AM
