AC not working
Old Mar 2, 2008 | 04:38 PM
seesaw_4's Avatar
seesaw_4
AC not working
AC not blowing cold. the compressor is not coming on either. Is there a relay or a fuse that works the compressor or am i screwed?
Old Mar 2, 2008 | 06:23 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Cecil,
this time of year you could simply employ 2-60 air conditioning...
Open 2 windows and go 60!
Seriously...do you have the auto temp control in your Ex?
Turn on the defrost to see if the A/C compressor kicks in...the defrost uses the A/C to minimize moisture in the cabin...
What temp is it where you are at?...it got up to 45 here today...BUT it is going to be 25 tomorrow!!!
I'm not thinking about A/C yet!
joe.
Old Mar 2, 2008 | 08:33 PM
robnoxiousauto's Avatar
robnoxiousauto
o.k. first what are you're static pressures ???????????? these trucks have a common problem with there low pressure cycling switch. it is adjustable but first you need static pressure incase the refigerant has leeked out. I it is low on refrigerant do go and buy blue tec or any other hydro caron based refrigerant there not ase sertified and they are explosive , they have the same basic properties as propane and they refigerant leam mat be in you're evaperator core making you're truck a bomb. but you cannot diagnose our repair most a/c issues with out gauges. however you can diagnose out the electrical portion by turning you're a/c on and jumping the low pressure switch. look on the large a/c line (low pressure line) close to the fire wall and you will find a two pin grey connector with a fuse jumper wire in stalled you're a/c compressor should click on if it does you're not fixed and not doing you're self any favor by ;eaving it jumped. As the refrigerant carries the oil used to lube the compressor and you wil destroy the compressor as well as spread debris from the exploding compressor through the rest of you're a/c system plugging the orifice tube as well as the evaporator core and condensor if you have any questions please fell free to email me dirrect at robnoxiousauto@hotmail.com
Old Mar 3, 2008 | 08:09 AM
seesaw_4's Avatar
seesaw_4
Originally Posted by X_Hemi_Guy
Cecil,
joe.
Hey joey well it got up to 72 here yesterday and i just kicked the ac on has we left from eating and the damn thing didnt work. And no i don't have the auto ac it is manual.. good talking to you and tell the gang hello
Old Mar 3, 2008 | 08:16 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Holy Cow!!!...we haven't seen 72° since prolly October!!!...I'm jealous...
Looks like Rob has you hooked up!
Good luck,
joe.
Old Mar 9, 2008 | 07:44 PM
SpringerPop's Avatar
SpringerPop
I suggest you do a search on FTE for "compressor clutch air gap".
Pop
Old Mar 9, 2008 | 09:23 PM
robnoxiousauto
compressor c;utch air gap not graeter then .060" and not less then .020"
Old Mar 9, 2008 | 09:26 PM
SpringerPop
They intermittently don't pull in when the wear gets to .050". Ask me how I know....
Fortunately, there's a pretty-quick fix for it, if that's his problem. See this thread:
https://www.ford-trucks.com/forums/5...-problems.html
Pop
Old Mar 9, 2008 | 09:27 PM
robnoxiousauto
in nthat case what you have is a week magetic pull in that is easily relaced.
Old Mar 9, 2008 | 09:33 PM
SpringerPop
Or adjust the shims to get the proper air gap.
See:
Pop
Old Mar 9, 2008 | 09:36 PM
robnoxiousauto
chances are you will end up needing to change the magnet eventually because the week ness is ussualy caused by a short in the windings i do about nine a year for the three dealers in town
Old Mar 9, 2008 | 11:20 PM
SpringerPop
The weakness on mine was just caused simply by the air gap being too wide. I fixed mine twenty months ago, and it went through two summers here in SoCal (where it gets a real workout) and worked as recently as this afternoon.
I realize there are wear limits, and someday the clutch will need a complete replacement, but until then, so far, so good. This technique has fixed a number of problems with members' clutches. That's not to say that coils don't short.
How do you determine the coil has shorted, DC resistance? What's the resistance of a good coil supposed to be? That would tell us when it's time to swap coils.
When you replace the coil, do you adjust the air gap, too, or just replace the entire clutch assembly?
Pop
schoo
17
Mar 15, 2022 09:39 AM
ranger332
2004 - 2008 F150
Oct 6, 2016 07:15 PM
90pioneer
Sep 6, 2016 10:41 PM
coolfeet
May 21, 2016 06:43 AM
