2000 expedition rought idle
Old Jun 5, 2010 | 06:02 PM
goblin53's Avatar
goblin53
my engine is fine until i drive it for a couple of miles. then if you come to a stop light the rpms jump up and down from 300 to 1200 rpms. it was dying til i changed the TPC ( throttle position censor). now it isnt dying but its still jumping up and down on the rpms for a few minutes while idling then it levels out again. this is a 4.6 engine not a 5.4.
Old Jun 5, 2010 | 06:51 PM
alloro's Avatar
alloro
Remove, clean, and reinstall the IAC valve (or replace it, your choice). It's at the top front of the throttle body.
Old Jun 5, 2010 | 07:24 PM
goblin53's Avatar
goblin53
is rem-oil ok or do i need to use carb cleaner? brake cleaner?
Old Jun 5, 2010 | 09:05 PM
alloro's Avatar
alloro
Carb cleaner does a nice job.
Old Jun 6, 2010 | 05:22 PM
bnovak's Avatar
bnovak
Yup, what he said.
MAF cleaner works too. And you can clean the mass airflow sensor and intake air temp sensor with it as well
From an experience with my POS dodge pickup, you might need to take the IAC out and soak it to fix the problem. (flip it upside down and basically fill it with cleaner.) They can get really gummed up
Old Jun 6, 2010 | 08:52 PM
trsimmons25's Avatar
trsimmons25
be sure to check the spark plug boots down in the well, they could collect moisture. I recently ran across this after I flushed my coolant and had some water spill. I pulled the COPs and found come moisture on the boots, and blew out the wells with some compressed air.
Old Jun 9, 2010 | 03:58 PM
goblin53's Avatar
goblin53
Thanks to you all the truck is running fine in park and neutral. but the rpms still jump in drive and reverse occasionally. but that i can deal with it only jumps about 400 rpms instead of 1000 rpms.
Old Jun 9, 2010 | 04:55 PM
alloro's Avatar
alloro
Maybe cleaning the IAC wasn't enough. You might end up replacing it.
F_TOUR
1978 - 1996 Big Bronco
Jul 3, 2019 10:20 AM
Matt2000expedition
Jan 14, 2013 10:53 PM
bikerbutcher
Sep 30, 2012 02:35 AM
OSU_AGR
1997 - 2003 F150
Sep 2, 2012 12:34 PM
Schmids4.9l
Jan 12, 2005 06:41 PM
