2003 Expedition hesitation
Old Jun 9, 2010 | 04:24 PM
Stockdale Dave's Avatar
Stockdale Dave
My 2003 Expedition has 114K miles. The last two weeks it has started to stumble and pull back when accelerating betwwen 20-55 MPH. Once it hits the cruise speed it's smooth. Idles like a new one. It's NOT throwing any codes. I have replaced the fuel filter, cleaned the throttle body and MAF sensor. I have not changed the plugs as to be honest I don't want to either face broken plugs in head or spitting them out after I change them. Any other ideas? Without codes I am lost as to where to look next.
Thanks for any help.
Old Jun 9, 2010 | 04:58 PM
alloro's Avatar
alloro
At 114K you're 14K overdue on the plugs. If the plugs are indeed the problem, then nothing else you do is going to solve anything.
Old Jun 9, 2010 | 06:36 PM
Shoob36's Avatar
Shoob36
I am having the same problem. Except eventually I got the error code PO300...or something like that...multiple mis-fires on multiple cylinders. Of course my wife read that error code as "trade-in for new truck".
We cleared the codes and I tried a can of Sea Foam hoping that would clear the problem, but sadly it did not. The CEL hasn't come back on but the truck is still running like crap in low MPH. So now I bought new plugs and just the boots and coils...hoping that will fix the problem.
Is there anything else to check? (Fuel filter is less than a year old.)
Thanks in advance.
Tim
Old Jun 9, 2010 | 06:59 PM
Stockdale Dave
I agree but i am behind on several maintenance items (transmission, brake fluid, coolant,etc.) and they wouldn't affect this. Changing plugs and /or COP is the last choice. If anything else can cause this then I am all ears..why twist off plugs unless it is the LAST option. How many have had fouled/defective plugs that didn't cause a misfire code????
kuszmaul
Modular V8 (4.6L, 5.4L)
Feb 13, 2016 06:55 PM
jaskracing
Aug 3, 2015 08:30 PM
ltramon45
Aug 21, 2013 02:07 PM
Carolyn Peters
May 3, 2013 08:44 AM
irvan01
18
Jul 20, 2002 03:40 PM
