how to increase MPG
Old Jun 7, 2010 | 10:46 PM
powerstroker100's Avatar
powerstroker100
okay, I will need to start driving like a 100 y/o grandma lol but for my future referance how would bad injectors affect mileage/ engine running and operation
Old Jun 7, 2010 | 10:49 PM
johnboggs21's Avatar
johnboggs21
well if their wore out and just pissing fuel, MPG and power will suffer.
Old Jun 7, 2010 | 10:53 PM
Dave Sponaugle's Avatar
Dave Sponaugle
My first step would be verify the speedo and odometer are accurate.
Second, average at least three or four tanks of fuel to get an accurate average MPG.
How the truck is sitting at the pumps can make a several gallon difference in how much fuel the tanks will take, which can have a large affect on what you see for MPG.
For the last several years I fill at the same station, sitting on the same side of the same pump every time I fuel up.
I also fill the tanks completely full.
When I do it that way, I get the most accurate MPG numbers on each tank of fuel.
Any other way, I have to average at least four tanks to get a decent average MPG numbers.
For my business use tax purposes I got in a habit of getting cash reciept's for my fuel, and then writing the odometer reading on each reciept.
Those records made it much better when doing the taxes with a side benefit of very good records of fuel MPG.
Next, are you just driving empty?
What kind of terrain do you normally drive in?
How fast do you normally drive?
What elevation are you normally operating in?
And what is your driving style?
Do you know what axle gears you have and what transmission do you have?
If I do jack rabbit starts, throttle flat on the floor as soon as I leave a stop light, run 75 or 80 MPH up and down the mountains here, I can cut my MPG numbers by 50% or more from what I can get if ease off the stop lights, coast up to stops and drive 60 MPH.
Driving style has the biggest influence on MPG numbers.
After that, gearing and cruise speeds have the second biggest influence on MPG numbers.
Third in the list is IP and injector condition, but that may actually move up to secong if they are in very bad condition.
If the exhaust smells like unburned fuel, you see white smoke while the engine is cold, you may have injectors that are leaking fuel when they should be closed.
In extreme cases, the injectors may let compression back into the injectors, which will cause the injectors to be rather hot and can also cause a knock on the compression stroke.
Looking at your signature I see a couple of my questions are answered.
4.10 gears and an E4OD should have you turning about 2100 RPM at 65 MPH.
So that is a good RPM for decent mileage.
But how much of the flat bed front sticks out past the cab catching wind?
The dually is also hurting the MPG numbers.
With a pintle hitch, how much are you towing something, how heavy is normal?
Looking at your information, I am going to guess your truck weighs about 7400 pounds empty.
So the faster you try to go from 0 to 60, the more fuel you will burn getting there.
Old Jun 7, 2010 | 11:09 PM
powerstroker100
This is very helpful thanks! terrain is flat, alot of stop and go traffic lately and I will not lie I still have powerstroke in my blood and need to remember to take it easy on red, 505ft elevation, on expressway I will do 60 tops, but most of the time its between 35-45 in stop and go, e4od transmission automatic and 4:10 gearing, I will admit that sometimes I think I'm speed racer in my truck but not very often when I calculated last I filled tank to full and counted miles on trip odometer
Old Jun 7, 2010 | 11:20 PM
powerstroker100
yes I am seeing that rpm at 65, bed sticks out about 6" on each side of cab, currently bed is half racked with wooden stakes, I do not pull very far, my uncles are all masons and I work with them frequently, they have a 22ft tri axle trailer and when I am not doing concrete floors I'll be using my truck as a mule around the jobsite, pulling pallets of red clay brick or conrete block, large Ibeams and Rebar for bridges, some really nice trowling machines, air compressors for those big jackhammers/chisels or even just pulling the trailer around spot to spot loading it up with smashed junk ashpalt, concrete, dirt, mud etc. I have not wired my truck for seven and four prong trailer wire yet so she only pulls big stuff around the site
Old Jun 7, 2010 | 11:50 PM
Dave Sponaugle
Idle time and job site running/pulling time eat into your fuel MPG numbers rather fast.
On my 86 with a mechanical speedo, it runs backwards when I am in reverse.
There have been a few times when I was plowing snow, 1/4 mile forward and then 1/4 mile in reverse that when I figured the MPG numbers they were gallons per mile numbers.
Out there plowing for 12 hours, burn 10 gallons of fuel and have 5 miles on the speedo.
So that figured at 2 gallons per mile as an average by the odometer.
If you calculated by speed and time, say 5 MPH average speed for 12 hours would be 60 miles driven, 10 gallons of fuel, 5 miles per gallon.
You have to look at everything you did during that tank of fuel when you figure MPG's.
If you spend 3 hours a day several days a week on a job site towing a load around the site, you might as well forget that tank for figuring MPG's if you want a true number that means something.
Old Jun 7, 2010 | 11:54 PM
johnboggs21
If ya do alot of stop and go, and towing, you might want to look into installing an aux. trans cooler. The E4OD is tough, but if you want it to survive, you have to keep it cool. Just a thought.
Old Jun 8, 2010 | 12:00 AM
powerstroker100
I think what I need to do is take a trip up to syracuse then back, would be about 180 miles round trip then I'll calculate
edit: also in short, idleing and stop and go basically annihilates fuel on these trucks? and how hard is it to install a cooler for one of these trucks I think I saw them for like $70 at napa, are these cheap ones or good? I would like to prolong my zf5 swap as long as possible for now, truck still needs alot of my attention to fix/ touch up this and that
Old Jun 8, 2010 | 12:31 AM
bojo68's Avatar
bojo68
Originally Posted by FORDF250HDXLT
of course the corrupt politics making diesel prices higher than gas (yeah,they know we do better and stick it to us) doesn't help.
Did you notice that up until 1977, Diesel was always CHEAPER than gas,(16.4 cents vs 27.9) as it was lower in the cracking process and cheaper to make supposedly. Then, GM brought out diesel cars and Pickups, and low and behold, diesel all of a sudden got more expensive than gas, by about the same amount as the improved efficiency. Imagine that.
Smells like a rat, walks like one...
Old Jun 8, 2010 | 09:14 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
They are rat's ... The whole oil industry is nothing but a bunch of greedy, liars, cheats and thieves backed and supported by greedy politicians, lawyers and government.
Sooner or later the people are going to have to put their foot down on this greedy monopoly mentality.
-Enjoy
fh : )_~
Old Jun 8, 2010 | 06:17 PM
peruses's Avatar
peruses
-Enjoy
fh : )_~
food markets headed the same way right now too
anyone care argue that tyson chicken is still gonna be cheep after they finish off the compitition, and get the regulations rewriten so that small scale operations can't meet the specs?
Old Jun 8, 2010 | 07:36 PM
bojo68's Avatar
bojo68
-Enjoy
fh : )_~
Don't hold your breath, the public just bailed out some of the biggest thieves in the history of mankind, and re-elected the politicians that did it.
Old Jun 9, 2010 | 08:11 AM
  #28
Festus Hagen
Methanoholic
And I was dead set against it ... Could you or I get bailout funds ... HELL NO!
Yet, The Mom and Pop shop is the backbone of our country.
-Enjoy
fh : )_~
camdaddy
Feb 2, 2015 08:15 PM
BigZ97
Dec 17, 2014 07:37 AM
bflora
Apr 23, 2014 10:01 PM
RedDevil460
53
Mar 29, 2014 08:16 PM
viperrtblck
Jul 2, 2006 03:52 PM
