need 550 hp
Old 06-04-2010, 08:31 PM
dgolan7's Avatar
dgolan7
dgolan7 is offline
need 550 hp
hey guy trying to find out what i need to do to get 550 to 600 hp out of this old 7.3 any ideas
Old 06-04-2010, 08:37 PM
dgolan7's Avatar
dgolan7
dgolan7 is offline
need help
also im gonna do it all myself but block work like if i need new rods how do i find out if it has the good one in it thanks . i know injector,turbo,hpop,maybe rods,ts chip the trans is done we will see if its gonna hold when im do and how hard is it to make a ford twin turbo. dad make everything sound easy but he works on gas motors not diesels
F350-6's Avatar
F350-6
F350-6 is offline
Lot's of ideas. First off, tell us what you have so far, how quick you want to get there, and how much money you have to spend?
Welcome to FTE.
Old 06-04-2010, 08:44 PM
dgolan7's Avatar
dgolan7
dgolan7 is offline
info
i have a built trans ts chip gauges, st pipe all the way out and thats it i just lifted it and got the rims and tires now ready to make it bad a** my young lady said if i spend more then 5000 she is gonna kill me. i do play in the mud but still take long trips in it sometimes i know i have a long way to go
Old 06-04-2010, 09:22 PM
F350-6's Avatar
F350-6
F350-6 is offline
Who built the tranny? Do you have PMR's? Did you just cut the muffler out or did you go with a new turbo back exhaust? How big of a lift do you have and what gears in the rear end?
If you have PMR's, it's generally advised to stay on the South end of 400 hp or you risk windowing your block. There are some running North of 400 on PMR's, but they tend to get nervous.
Old 06-04-2010, 09:40 PM
dgolan7's Avatar
dgolan7
dgolan7 is offline
downpipe
4in downpipe and 5in exhaust all the way out and tim at branden tran built it hes is the best around here for anything with big power he said all i need is a trans computer and it golden he said but hes a great guy i dont think he would lie and he backs it for 650 he said
Old 06-04-2010, 10:10 PM
dgolan7's Avatar
dgolan7
dgolan7 is offline
more
need more please thanks
Old 06-04-2010, 10:14 PM
Visseroth's Avatar
Visseroth
Visseroth is offline
There is a lot you can do but I don't know if you can do it within $5K
Old 06-04-2010, 10:20 PM
F350-6's Avatar
F350-6
F350-6 is offline
Exhaust sounds fine, what about air intake? The crappy stock box will dust your engine if you start adding power.
Now don't take this the wrong way, but we really should have a conversation about your transmission too. Did he give you anything in writing saying he backs the tranny up to 650? What about torque numbers? If he's used to gasser trannys, a diesel puts out a lot more torque at much lower rpm's.
The trans computer comment is also of a concern. You can adjust line pressure with a chip, or you can adjust it within the valve bodies, but the 4R100 doesn't need some separate trans computer to go along with it.
I'd politely ask if there were any shift kits like transgo or sonnax installed in the valve bodies. I'd also ask what specifically was done to make the tranny better. Just tell him you're trying to learn about this stuff.
I don't know where all the big HP guys are. I figured by now the others would be chiming in. Are you looking to make those numbers on straight fuel, or are you considering drugs? (meth injection)
Old 06-04-2010, 10:25 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
You can barely get a turbo & injectors for $5k. You'll need a lot more than that for 550-600 hp......
Old 06-04-2010, 10:35 PM
papadelogan's Avatar
papadelogan
papadelogan is offline
Snowboard season cometh..
Just curious why you "need" 550hp+...
Old 06-04-2010, 10:53 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Same reason I "needed" 450.
Old 06-04-2010, 11:33 PM
Chvyrkr's Avatar
Chvyrkr
Chvyrkr is offline
Aren't you nervous?
I'm not nervous...
550ish can be had with 238's (100% or 200% nozzle) and a modded H2E, with GOOD tuning.
Stock 17* in good shape will support 238's, the stock fuel system will support them as well. You'd be better off with more oil though, and more likely to hit your goal.
But, 550 is gettin close to the head lifting range, so add head studs. Valve springs are a really good idea over 40ish pounds of boost. Depends more on the turbo IMO though, and how much backpressure you're workin with, since backpressure is almost always higher than boost. And don't replace valve springs without replacing pushrods, or you'll just be goin back in there after a while.
Don't forget a boostfooler, and the stock IC pipe boots probably won't like the boost you're pushing.
550 for 5 grand is almost impossible. Unless you're sponsored or something.
Plan on 7-10 grand, and that's all motor parts. If you go tearin around on 550 without trac-bars, plan on replacing a rear end. So go ahead and add some more money for those.
Then add some more for whatever I've forgotten to mention.
550 that runs right, total package not skipping things on the rest of the truck, is probably gonna be around 12k.
Old 06-05-2010, 12:34 AM
spdmpo's Avatar
spdmpo
spdmpo is offline
Welcome. I don't know how old you are or what your knowledge and background is with these trucks but I'll politely say first that your posts are hard to read and understand. Just try to make sentences that can be comprehended and not run on and on and be specific with what's been done to your truck and the transmission. Then people here can help you a little better I'd bet.
But with a $5000 budget methinks you should take a breath and slow down a little and read up around here. You might have your sights set a little high thinking you can get 550hp. It takes a lot of money to make a 7.3 live at that level. 5 grand ain't gonna do it. You'll need $2000 easy off the bat just for a turbo to support that power. There's a lot more to it than just slapping some big injectors in and getting a chip like is posted above. I'm not a big power guy so I can't help with specifics but I know what it would take and it's too rich for my blood.
Old 06-05-2010, 12:46 AM
Chvyrkr's Avatar
Chvyrkr
Chvyrkr is offline
Tuning is key.
There have been quite a few trucks out there on stock forged bottoms makin impressive power in the last year or so, with the latest lessons learned.
What you're starting out with makes the biggest difference in price.
01-03 (PMR) 7.3? 15-20k to get close to 600.
OBS-00 (Forged) 7.3? South of 15k, probably closer to 10-12k.
Quick Reply: need 550 hp
