Sponsored by: Auxito
OVERHEATING PROBLEM
Old Jun 4, 2010 | 06:54 PM
big-papa's Avatar
big-papa
OVERHEATING PROBLEM
I have a 2001 f-150 4.6L and heres my problem. I changed the thermostat still overheating so i changed the water pump still no luck.i was wondering if anyone out there has this problem or has had this happen to them befor.If someone could shed some light on this for me it would be great or even know what the problem is would be way better.thanks for you time
Old Jun 4, 2010 | 08:49 PM
steve(ill)'s Avatar
steve(ill)
exactly what happens. does it puke water out the cap ? does the temp just go too high on the gauge? does it happen when on the highway ? when AC is on? are you using water, then it gets hot, or ??
Old Jun 4, 2010 | 10:31 PM
big-papa's Avatar
big-papa
no water out the cap, the temp go's high on the gauge after the truck has been running for 10 mins or so thats when the temp gauge go's to the red.no ac on using antifreeze and still overheating.no white smoke out the tail pipe i'm puzzled
Old Jun 5, 2010 | 11:25 AM
steve(ill)'s Avatar
steve(ill)
sounds like no water flow. either the radiator is plugged up, motor water jackets plugged up, or pump dont work very good. since you have a new pump, i think i would drain and flush real good and watch the flow out the drain. i put a garden hose TEE into the heater line so i can turn the hose on 20 GPM and let it shoot out the radiator tank cap or drain and see what is actually happening.
Old Jun 5, 2010 | 12:45 PM
powersmoked's Avatar
powersmoked
clutchfan? electric fan? Radiatror............ did you use a motorcraft t-stat? you have enough coolant and no air bubles?
Kregj
Jun 6, 2014 05:37 AM
broncoman72
1997 - 2003 F150
19
Nov 7, 2010 04:53 AM
billyblanks
1983 - 2012 Ranger & B-Series
Apr 13, 2010 06:35 AM
powerstroke26
Sep 21, 2007 02:21 AM
cz2kkk
Jun 14, 2003 11:56 PM
