Overheating problems
Old Jun 5, 2014 | 01:05 PM
Kregj's Avatar
Kregj
I have a 96 f150 and it keeps overheating. I've fixed the thermostat, flushed the radiator, fixed the fan and it keeps overheating. Any thoughts???
Old Jun 5, 2014 | 01:18 PM
General Geoff's Avatar
General Geoff
What engine? How long does it take to overheat? Is the coolant level topped up? Does it go down when running? What are the ambient temperatures like? Does the heater work?
Old Jun 5, 2014 | 01:23 PM
Kregj's Avatar
Kregj
300 inline6 4.9l, it overheats a little bit after I turn it off, my coolant level is topped up, yes the heater does work. Has only overheated while driving once and that was before I had anything done to the truck.
Old Jun 5, 2014 | 01:33 PM
General Geoff
When you say 'overheats a little bit,' how far up the gauge does it go?
It's normal for the engine to get a little bit warmer after being turned off due to heat soak, because the coolant is no longer circulating or being cooled by the mechanical fan, so the remaining heat from the engine is soaked up by the coolant in the block, which slowly dissipates over the course of a few hours.
I wouldn't worry if the needle doesn't get over the 2/3 mark, as long as it goes back down to the halfway point shortly after starting the engine again.
Old Jun 5, 2014 | 02:08 PM
Kregj's Avatar
Kregj
Ok thanks!
Old Jun 5, 2014 | 11:02 PM
drjoe171's Avatar
drjoe171
Nice to check it with a real thermometer or laser temp gauge.
Do you hear water running like there may be air in the system?
Old Jun 6, 2014 | 05:37 AM
Kregj's Avatar
Kregj
Every once in a while
1994FordF-350MegaCab
Nov 19, 2018 07:38 AM
snknby123
22
Dec 14, 2015 08:59 PM
bkeljda
46
Oct 1, 2015 10:05 AM
blueeyedfordguy
General Automotive Discussion
Oct 12, 2013 03:46 PM
Kales Veggie
1997 - 2003 F150
May 29, 2012 11:10 PM
