Still working on temp problem
Old Jun 6, 2010 | 12:39 PM
  #31
sdetweil's Avatar
sdetweil
Originally Posted by ALBUQ F-1
Looking at my numbers and Larry's, using the infrared, do you really doubt he has a problem? It would definitely help to have gauge readings but I don't think he's imagining there is a problem.
I'd be more interested in compression test results at this point.
Larry, I can't remember; have the head gaskets been replaced in recent times on this engine? With 8BA's, it is possible to have the head gaskets flipped, bank-to-bank, which partially blocks some of the head passages.
There are also some brands of head gaskets out there that are missing one of the cooling feeds to the head from the block. See below.
same mistake can be made on the 351c head gaskets..
Sam
Old Jun 6, 2010 | 01:10 PM
  #32
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by 52 Merc
Wow, Ross, that's a huge boo-boo! Thanks for that info! There's probably more than one of us flatty newbies that never would have known or realized that the gasket could be wrong. Do you have a recommendation (or a warning), for future reference?
Well, there's more to the story. There are really only two companies making flattie head gaskets now, Victor Reinz and Best, maybe Detroit Gasket. When you buy FelPro, the head gaskets (only) are actually VR's. There was quite a discussion on the differences between the two gaskets (the ones with/without the hole) as to which was correct. Water flow in an 8BA is supposed to be from the front of the block, to the rear, up into the head at the rear, toward the front. Some water goes from block to head at each cylinder, but the big passages are to encourage that kind of flow. The 8BA cooling system was considered a significant improvement over the 59-series engines'.
Some say the gaskets without the "extra" hole at the rear are part of the 8BA scheme, and better balances the flow. Others have had cooling issues using that gasket. I don't even know if those gaskets are still being sold.
As far as flipping them, it only affects one or two holes, so it will run cool most of the time but when it's hot, there's a problem. I don't remember exactly, but I think it's the extreme front or rear holes that get blocked. You have to look close to see that it's happening. MTFlat may have more info on this, he was part of the discussion.
Here's a piece on Red's Headers "Engine Talk" page. It says it all about cooling issues in a short piece.... Red's Engine Talk
Old Jun 7, 2010 | 12:22 AM
  #33
Julies Cool F1's Avatar
Julies Cool F1
Well Ross based on the input that has been revised on the thread, I agree with you. But based on the PM inputs I recievend, the engine was running normally.
The technical question is interesting, but after getting different reading than were posted here, I have to ask if the inputs we are recieving are reliable at all. You are MUCH better at Flathead characteristics thanI am and I think your input will be much more qualified than mine at this point! Have fun!
lbrauer
WTB - Parts & other
Jul 21, 2013 09:33 AM
lbrauer
15
Nov 22, 2010 06:09 PM
lbrauer
19
Aug 26, 2010 10:15 PM
lbrauer
Jul 25, 2010 01:03 AM
lbrauer
34
Jun 26, 2010 03:46 AM
