TEMP GUAGE FOR 52 F1
Anybody out there got an extra temp guage that will fit the guage cluster in a 52 F1 truck they want to part with. Mine kept blowing the fuse and found out why yesterday one of the post screws came out of the back of the guage. I had an old one and put it in but it doesn't work stays on hot and doesn't go to cold when key is turned on. I was wondering also if maybe I could sodlier the post back in the back of the guage and also do the same to the small wire inside the guage. Has anyone done this before and it worked?
Thanks for anything you can do,
Lbrauer
braular@yahoo.com
713-410-7481
Lbrauer
braular@yahoo.com
713-410-7481
Was that the brand new one I sent? I have one more NOS left but it's promised to someone else.
There are a number of them for sale on e-bay at the moment.
NOS 1951 FORD TRUCK TEMPERATURE GAUGE 1C-10883-A NICE!!: eBay Motors (item 360317490205 end time Nov-14-10 13:38:02 PST)
51 52 FORD F-1 PICKUP TRUCK SPEEDOMETER GAUGE SET DASH: eBay Motors (item 190465871062 end time Nov-14-10 16:58:59 PST)
thanks Julie I have one coming from e-bay that I hope is a good one from what the decription says. Me and those temp guages don't get alone to good it seems. I don't know if I tighten them to tight or what. I hope to get the old truck back on the road soon.
Thanks again Julie your the best.
So is the new one coming - BE GENTLE!
Well Julie I got the temp guage from e-bay and put it in truck but as my luck has it when the key is turned on it doesn't go to cold but when you start the truck it slowly goes down and comes right back up. I changed the wires on the back around thinking I had the reducer wire on the wrong stud and didn't make a difference in the guage. Do you happen to know what might be wrong or did I purchase a bad guage.
Thanks as always for the responce,
Larry Brauer
Braular@yahoo.com
Larry Brauer
Braular@yahoo.com
Oh Larry, I gotta feel bad for you! I've never seen anyone have so much trouble with these!
The slow move to "C" isn't unusual for a 6 volt gauge especially with a voltage reducer.
Your other gauge worked ok until the stud broke off right?
Take the gauge out and test it.
Take four 1.5 volt AA batteries and touch them end to end - negative to positive - as in a flashlight.
With a seperate wire connected to each gauge post, touch one wire end to the positive end of the stack of batteries and the other wire to the negative end of the stack of batteries. The gauge should creep to "C." Then take one battery out, touch them back together and retest. The needle should move a little toward "H." If it does it's ok.
Let me know what happens.
