Ring gears
Old Jun 2, 2010 | 09:26 PM
TheTowingCowboy's Avatar
TheTowingCowboy
Ring gears
Correct me if this statement is wrong
the gears for a Sterling 10.50 will work in our Sterling 10.25's
I ask cause I think my 75 has 4.10's in it do to the vin plate, and I am going to check, anyways if I do, I need to put gears in my sterling (Its 3.55) also anyone got a LSD or something they would sell me cheap? Cause I got a UNLIMITED (You heard me right) Unlimited slip diff. Anyways thanks guys. Also if I put 4.11 gears in it, would that matter? I dont think .01 would hurt but you never know.
Old Jun 2, 2010 | 09:44 PM
1997F-350's Avatar
1997F-350
10.5 will work
Old Jun 2, 2010 | 09:51 PM
TheTowingCowboy
Thank you 97 =) appreciate it and I thought so just double checking.
Old Jun 2, 2010 | 09:59 PM
1997F-350's Avatar
1997F-350
if it was me i'd look for a wrecked 99-03 with a 3.73 LS but thats just me...my 97 truck had 4.10's....are you towing heavy if not youll get better mileage but you know that
Old Jun 2, 2010 | 10:35 PM
Talyn's Avatar
Talyn
those were special order for the 3.73.
Old Jun 2, 2010 | 11:31 PM
rusty1161's Avatar
rusty1161
Does anything special need to be done or used to install the 10.5" gears in a 10.25" rearend?
Thanks.
Rusty
Old Jun 2, 2010 | 11:38 PM
1997F-350's Avatar
1997F-350
there is some info out there. i cant remember off the top of my head....3.73 was special order for super dutys 99-03 or the ls was???
Old Jun 3, 2010 | 08:49 AM
Talyn's Avatar
Talyn
The ring gear was as far as I know.
Friend of mine had to order his from the factory to get 3.73.
Its friggen weird to drive with the zf6 and 3.73's after driving mine with 4.10's. haha.
Old Jun 3, 2010 | 08:51 AM
Talyn's Avatar
Talyn
Thanks.
Rusty
IIRC, you need different bearings for the pinion.
The 10.5 has smaller pinion shaft than the gen 2 10.25.
If you can get a pinion that matches the gen 2 10.25 and will mate up with the 10.5 ring gear, that would be mint.
I believe you have to swap carriers too. I think you can swap carriers and not swap gears as well. To much to remember. haha.
The 10.5 carrier has 3 spiders, which is a lot better if you are running tires over 35 inches.
37 inch tires really tear up the 10.25's spiders.
Old Jun 3, 2010 | 08:52 AM
Talyn's Avatar
Talyn
Ford 10.25 & 10.50-Inch Axle Tips - Four Wheeler Magazine
here is the best article i've found on stearling axle info.
Old Jun 3, 2010 | 06:14 PM
TheTowingCowboy
The truck will tow and sled pull a little, also I plan on running a 35. The truck is originall a 4.10 truck so I will kep it that way, just to kind of match the vin.
51MHF5
Jun 22, 2013 09:56 PM
302flareside1992
Offroad & 4x4
Jan 10, 2013 10:25 AM
f1001969mike
Jun 12, 2011 05:44 PM
austynn2001
Offroad & 4x4
13
Nov 14, 2006 07:03 PM
