Offroad & 4x4
Lock Right changeability in Sterling
Old Nov 6, 2006 | 08:57 PM
austynn2001's Avatar
austynn2001
Hello everyone. I have a 1986 F-250 with the Dana 50 front end. It has a somewhat built 466, a 4 speed, and a Sterling rear with 4.10's and a Lock Rite. It revs pretty high driving around town, but not enough to bother me. However, going up the highway it stays at a pretty high RPM. I was offered a Sterling rear with 3.55's for cheap today. I also already have a Dana 60 front end that is 3.54 (i believe) that I was going to regear to 4.10 whenever I got enough money. I was wondering if I should keep the 4.10's and regear the Dana 60 or if I should buy the Sterling with the 3.55's. Also, if you vote for option number 2, I need to know if my brand new Lock Rite would be able to be put in the new rear end. Thanks, Austynn.
Old Nov 6, 2006 | 10:29 PM
fishmanndotcom's Avatar
fishmanndotcom
if it were me it'd be a no brainer! get the sterling! and yes they interchange as far as i know!
ditch the D50, finsih building the D60 and get the sterlign rear. if you tow with this truck do 4.10's otherwise i'd just stick to 3.55's unless doing 4.10's is easier/cheaper!
-cutts-
Old Nov 7, 2006 | 03:43 PM
jgreen's Avatar
jgreen
make sure the sterling is not out of a superduty, it will have an 8x170 lug pattern which is different than yours. sound like you are running a pretty good setup as it is, so if you want, i can just come get that dana 60 from you and you won't have to make any more changes.
justin
Old Nov 7, 2006 | 08:45 PM
austynn2001
Well I know it's out of an older truck, but I was just wondering if the different gearing would stop me from being able to swap my lock-right over to the other axle. Thanks, Austynn.
Old Nov 7, 2006 | 09:21 PM
bremen242's Avatar
bremen242
you should be fine. the gearing only affects the ring and pinion gear, not the spider gears. goto the powertrax web site and look up the applications for the sterling rear. the part ##s should be the same.
Old Nov 7, 2006 | 09:59 PM
82F100SWB's Avatar
82F100SWB
There is no carrier split on a Sterling, so, even a full case locker can be swapped with no issues.
Old Nov 8, 2006 | 09:06 AM
74fordtruck's Avatar
74fordtruck
what size tires are ya running? My 4.10's and 35's are perfect for around town or on the highway. I stepped up from 3.50's, which were good with stock tire, but suck with the 35's.
Old Nov 8, 2006 | 11:57 PM
mustange70's Avatar
mustange70
The only thing that will prevent you from using the lockright in the new axle is if it is a ford trac loc limited slip diff, as your locker will not work with that carrier. Personally i'd keep the 4.10''s and regear the 60, i'd pick up that sterling up anywa to have for parts and and what not cause people will charge an arm and a leg if they know what they have.
Old Nov 9, 2006 | 10:13 PM
austynn2001
I am currently running 33's, but I plan on doing a 4" lift and 38-42" tires.
Old Nov 10, 2006 | 06:54 AM
Briansshop's Avatar
Briansshop
Well,...then you don't want those 3.55s for sure.Might need to go lower than the 4.10s.
Brian
Old Nov 10, 2006 | 11:35 PM
fishmanndotcom
Brian
not to change the subject but dont you frequent TDS? i think i have seen you post mostly in the upgrade section about offroad related stuff!
-cutts-
Old Nov 11, 2006 | 06:28 AM
Briansshop's Avatar
Briansshop
Yea, how's is going fishmann?
Brian
Old Nov 14, 2006 | 06:55 PM
Customz's Avatar
Customz
keep the 4.10s and regear the 60.
Old Nov 14, 2006 | 07:03 PM
65'f1004x4conver's Avatar
65'f1004x4conver
I have 38"s and .410 and im pretty pleased with it
96ford250
Jul 16, 2014 07:57 PM
51MHF5
Jun 22, 2013 09:56 PM
nstueve
Oct 11, 2010 11:08 AM
427 fordman
Apr 9, 2010 09:37 PM
76 4x4 460
Jul 17, 2003 10:52 PM
