1978 f250 lighting help
Old Jun 1, 2010 | 08:42 PM
hannahbarie's Avatar
hannahbarie
Hey guys can anyone give me a idea .On my old truck the front turn signals are going crazy . With lights off they work fine but when I turn the lights on the arrows on the dash stay lit, and the outside blinkers work but I dont have parking lights .I have checked the bulbs and they are ok . I was thinking a bad ground?? Anyone out there have an idea ? Thanks Mark
Old Jun 1, 2010 | 08:52 PM
plumber01's Avatar
plumber01
Possibly check the relays
Old Jun 1, 2010 | 08:54 PM
hannahbarie
Thanks Robert i did not think about that . I will give it a shot tomorow . hopefully it is an easy fix like that ,Mark
Old Jun 1, 2010 | 08:56 PM
plumber01's Avatar
plumber01
Hope so, Some electrical problems can be a night mare, Not too bad on the older trucks, but problems none the less
Old Jun 1, 2010 | 08:59 PM
hannahbarie
Yea , I am dreding it if it is a bad gound somewhere . Back lights are all working normal. But shes not my daily driver so I got time if need be .Mark
Old Jun 1, 2010 | 09:12 PM
fmc400's Avatar
fmc400
MSEE
There aren't relays in the turn signal circuit; just a flasher. This does sound like a ground issue.
Old Jun 1, 2010 | 09:23 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I also concur to check the grounds. Each lighting pigtail is grounded to the core support near each headlight.
Josh
Old Jun 1, 2010 | 09:25 PM
hannahbarie
fmc400,Thanks for the bad news .lol. I will start poking around tomorrow maybe i will get lucky . Thanks Mark M
Old Jun 2, 2010 | 04:15 AM
plumber01's Avatar
plumber01
Not saying you're wrong or anything but the FLASHER is a RELAY
Also check the bulbs and make sure they are TWO filament bulbs(for blinking)
Take a look at the harness to see if there are any cracks or splits in them.
I always start with the easiest and cheapest things first when i am not sure.
Old Jun 2, 2010 | 08:22 AM
fmc400's Avatar
fmc400
MSEE
I've heard a flasher referred to as a relay in several other places, but it's not correct. The true definition of a relay is a switch that is controlled by another circuit. The control signal is "relayed" to the switch, hence the name.
A relay can have three terminals at a minimum. The flashers in these trucks have only two terminals. The current through the switch itself opens and closes the switch through the use of a heating element - hence the term "thermal flasher." Because the control signal is not separate from the switch itself, it is not a relay.
No offense meant at all - the only reason I'm bringing this up is because if you tell me to look for a relay, I'm going to look for a little square box, like the horn relay. Then I'm troubleshooting the wrong circuit. If I need to be looking for a flasher, tell me to look for the flasher.
Old Jun 2, 2010 | 09:38 AM
plumber01's Avatar
plumber01
a current relay with a bimetal strip (2 points on it)....STILL A RELAY almost like a thermostat relay.. same component, different application. The other RELAYS you are talking about I believe have the coils in them
Old Jun 2, 2010 | 09:48 AM
bassdude's Avatar
bassdude
had the exact same thing you're describing on my 76. turned out to be bad bulb sockets. i only figured it out after i went through most of my wiring including replacing the column harness.
Old Jun 2, 2010 | 01:43 PM
Joseph69's Avatar
Joseph69
Yep, the sockets have gone bad on three dents I've had. The ground wire for the bulb is near the top of the bulb close to the glass. When that rusts away you cant tell it was or should be there.
Dash lights for blinkers come on when no ground is present.They are supposed to do that.
Old Jun 2, 2010 | 02:27 PM
hannahbarie
I just checked the sockets and you were right . I rigged up a ground wire and bang working like normal . Will order new sockets . Thanks guys for all your help with this ,Mark M
HVACTOM
Feb 14, 2015 04:33 PM
cherrybomb37
Oct 8, 2014 10:16 PM
JoeKramer
Nov 4, 2012 04:07 PM
Zack Hughes
May 26, 2012 07:55 AM
Munch
Jul 4, 2006 05:26 PM
