lost guages and accelerator
Old Jun 1, 2010 | 07:26 PM
dunbar15's Avatar
dunbar15
I have a 2000 7.3 with 170K on the ticker, today I went to drive the truck and all the guages were reading 0 or off, like when the truck is off and the accelerator intermitently works, truck idles fine but will not rev up when accel is pressed, I do have a remote starter on the truck and working on the theory that the computer maybe got confused by the remote starter I disconnected both batteries for 5 minutes to hopefully reset the computer. When I turn the key to the point where it should say wait to start only the battery and I think airbag lights come on on dash, at bottom left, none of the other lights come on, truck starts but no rpm readout. I did have the oil pan replaced 2 weeks ago so not sure what they had to do for that, know they had to lift motor up or out, dont know if cab was off, any help with this woul be greatly appreciated..
Old Jun 1, 2010 | 08:24 PM
Duzitall's Avatar
Duzitall
Perhaps there is a bad fuse, circuit breaker or fuseable link for dash and pedal?
Old Jun 1, 2010 | 08:25 PM
zx250's Avatar
zx250
Of the next Riffraff East
Check fuse #19 under the dash.
Old Jun 1, 2010 | 08:50 PM
dunbar15's Avatar
dunbar15
thanks
Will check fuse tomorrow.. Thanks
Old Jun 1, 2010 | 10:36 PM
Bergerson's Avatar
Bergerson
x2 on fuse 19, thats the one!
Old Jun 1, 2010 | 10:46 PM
firestroker8706's Avatar
firestroker8706
Def check the fuses. I had the same problem, but I think mine was 37. There's a short that develops in the wires that lead from your overdrive switch through the steering column. Mine died everytime I hit that button (and I went through about 6 fuses before I got it narrowed down.) It might be a good place for you to start.
Old Jun 2, 2010 | 07:56 AM
dunbar15's Avatar
dunbar15
fuse 19 blown
Thanks guys, hopefully I dont have a short, should know within a few weeks of replacing, if it blows again its going back to stealership, they replaced the oil pan, I was told its a big job and maybe they pinched a wiring harness, hopefully not and this is the end of it, also could be the harness for overdrive as suggested by firestroker.. You guys are awesome, this site is awesome. Will join as a supported this week, how much is it ?/
Old Jun 2, 2010 | 08:08 AM
Duzitall's Avatar
Duzitall
Cheaper than going to the movies. Just click on a "supporter" banner under someones name in any post.
Old Jun 2, 2010 | 08:31 AM
zx250's Avatar
zx250
So, the fuse was blown or have you checked it yet?
603MudF350
Jan 4, 2015 10:42 PM
dougsbart
Aug 20, 2013 07:16 AM
pwrstroketx
Feb 26, 2008 07:15 AM
cef2lion
Aftermarket Products
Nov 11, 2005 02:22 PM
firemanV10
Oct 8, 2001 08:19 PM
