Love it Jr, had it gone thru yesterday new front brakes, oil and trans fluids changed have to put a gasket on the left valve cover new door locks cause there aren't any keys for the ones that are in it but its awesome
good maybe you can help me out -the a-c in the truck took a dump again -was blowing kinda cold tried charging it and it went HOT -according to the gauge it's charged a lot but no cold -yes the compressor is running ?????
are you sure it's running? the whole clutch going round?
Originally Posted by jr32560
no leak as I see just not cooling was up on the gauge before I started trying to charge it ????
put too much in, and it will come bellowing out on the relief port. low pressure cut out switch probably bad, pull the harness off it, and jump it to see if the compresser kicking in.
