Maryland Chapter Join Chapter, Leader:
June chat B/S thread
Old Jun 16, 2010 | 08:07 PM
  #601
jr32560's Avatar
jr32560
Originally Posted by dustybumpers
blend doors working? could be makeing cold, and going right back outside, ot evaperator could be freezeing up
I would feel or see cold or hot on one of the hoses though right?
I'm so confused -it's like the same thing it did last time --charged worked for a bit then starting getting warm then wouldn't take a charge-as the gauge reads it's over charged now --if the compressor is working right?
going to the 2-60 air system
Old Jun 16, 2010 | 08:11 PM
  #602
jr32560's Avatar
jr32560
no, but if you take a freon bottle, and store it in the freezer, it will suck it out when you hook it up. is the compresser running steady, or cutting in and out?
so a vacuum pump won't recover it ? crap how in the world do they recover freon then?has to be a way? maybe an old compressor off of a fridge and solder on some fittings? one tube sucks and the other pushes out right?
use the freon hoses from my gauges to push it into a canister?
Old Jun 16, 2010 | 08:13 PM
  #603
80351's Avatar
80351
I thru a can in mine the other day cause the guy said it was low
but I'm rather certain it has a nasty leak but I'm not real concerned
about it at the moment
Old Jun 16, 2010 | 08:14 PM
  #604
dustybumpers's Avatar
dustybumpers
they make a recycle machine, but unless you have $10,000 to buy it , I guess you will ...........
Old Jun 16, 2010 | 08:15 PM
  #605
BPofMD's Avatar
BPofMD
Veteran: Navy
When WILL you be concerned, Dave?
Old Jun 16, 2010 | 08:16 PM
  #606
jr32560's Avatar
jr32560
yeah freezing the bottle will assist it I'm sure-gonna check into the freon recovery with an old compressor off a fridge or something though-bet there is something on the internet redneck recovery ???
Old Jun 16, 2010 | 08:18 PM
  #607
80351's Avatar
80351
When I get everything else done
  #608
dustybumpers
system probably has a leak, and you keep adding freon, withou vacumeing down the system. if you keep adding freon it won't work. think of it as putting rocks in a glass, then putting in the water, you can still get a drink, but there;'s not a whole lot of water in there TOO drink. mabe should have used beer as the example?
Old Jun 16, 2010 | 08:19 PM
  #609
jr32560's Avatar
jr32560
  #610
dustybumpers
when he has to use anti persperant on his *****
Old Jun 16, 2010 | 08:20 PM
  #611
80351's Avatar
80351
Good one Charlie
Old Jun 16, 2010 | 08:21 PM
  #612
flyer122's Avatar
flyer122
hot and humid how's PA same?
I don't know I never made it out of the house.
  #613
80351's Avatar
80351
Hey Charlie leave my tow ***** out of this speaking of which I have to put the hitch on so its not banging around in the bed
Old Jun 16, 2010 | 08:23 PM
  #614
flyer122's Avatar
flyer122
Great here Kathy...how U?
I'm doing okay. Thanks for asking.
Old Jun 16, 2010 | 08:24 PM
  #615
flyer122's Avatar
flyer122
They do make stuff for that. LOL
