Rear Window Install
Old Jun 2, 2010 | 10:37 PM
DEADANIMAL's Avatar
DEADANIMAL
Who do you get your parts from?
I have never gotten any directions from a parts vendor since I've been building! Except like a complete harnes or something like that.
Deadanimal
Old Jun 3, 2010 | 07:14 AM
r_reed's Avatar
r_reed
we put in some flat windows recently (2 people). we found it very useful to have some of the big suction cups (kind used on big glass panels) on the outside of the windshield to press up or in on the windshield as needed. dick r
Old Jun 3, 2010 | 12:17 PM
KJLYPW's Avatar
KJLYPW
I had my rear glass cut locally, off of a cracked original. Same issue couldn't get it to fit was too tight at the weld seams on the bottom corners of the frame, so I had the glass shop sand down the size about 1/16 all around, which they did at no extra charge. Fit snug but installed without execesive force being required.
Old Jun 10, 2010 | 02:40 PM
tip49's Avatar
tip49
Success!
Glass installer paid a house call today, after 40 minutes, front and rear window were installed.
We put the windshield in first, the four tabs that hold the rubber in needed tweaking (bent up so the glass would clear; have not bend them back over yet. The rubber puckers where the tabs are.
The back window went in with no problem, it was cut by the glass shop from the broken original. Worth noting is the installer pointed out that the rear window is only sitting in the opening, the inner upholstery will eventually hold the rubber seal from popping out, as it sits in the inner groove in the rubber.. I won't drive the truck for some time yet, but will make sure the upholstery is installed around the rear seal first.
Another hurdle overcome, feels like I can see the completion from here. I'm going to install my instrument cluster today..news at 11:00
Later
Tom
Old Jun 10, 2010 | 05:24 PM
Julies Cool F1's Avatar
Julies Cool F1
Originally Posted by tip49
Glass installer paid a house call today.... Worth noting is the installer pointed out that the rear window is only sitting in the opening, the inner upholstery will eventually hold the rubber seal from popping out, as it sits in the inner groove in the rubber..
Tom
It's very odd he should say that because the seal should be holding the window in - not any part of the interior liners.
Mine is IN there and I have not interior stuff yet.
Old Jun 10, 2010 | 08:04 PM
52 Merc's Avatar
52 Merc
Tom
I agree that doesn't sound right. It's possible you have the rubber installed incorrectly on the glass. Can you snap a pic and post it?
Old Jun 10, 2010 | 08:26 PM
tip49's Avatar
tip49
window install
I can post a picture, I'm pretty sure the glass is installed correctly; the largest flange of the rubber is pulled out over the cab flange. I'm sure the window will stay in , but the inner lip that seats into the uphostery will definitely hold the window in place.
I'll take pics tomorrow.
Old Jun 10, 2010 | 10:20 PM
52 Merc's Avatar
52 Merc
Did he install the window from the inside or the outside? I seem to recall the wider lip is on the inside. The small lip grabs ahold of the pinchweld and sits on the outside. The glass is supposed to install from inside the cab.
rannaska
46
Jan 5, 2021 12:12 PM
lpmorgan
33
Dec 27, 2014 08:39 PM
FordFanboy
Sep 11, 2014 09:21 PM
mjv98lariat
Aftermarket Products
Jul 26, 2013 06:52 AM
ssj7kids
Sep 22, 2012 06:07 PM
