Rear Window Install
Old Sep 21, 2012 | 04:13 PM
ssj7kids's Avatar
ssj7kids
Rear Window Install
Going to install rear window this weekend....
One question: Mastic goes between the glass and the rubber, got it.
Rubber goes on the window and then the window and rubber goes onto the cab from inside. Using 'rope' on the outside to 'slip the lip'.
QUESTION: Do I put mastic between the cab and the rubber gasket? Seems like I should, BUT I'm thinking that with the rope pull process, I'm gonna get mastic ALL over the place... just a big mess waiting to happen.
Any experienced advice?
Old Sep 21, 2012 | 05:24 PM
old_dan's Avatar
old_dan
Yes... Put some of the non hardening sealant there.. It'll make a giant mess, but some sealant will be there. Get a roll of paper towels and a gallon of mineral spirits paint thinner ready to wipe up the excess.
Old Sep 21, 2012 | 05:42 PM
sdetweil's Avatar
sdetweil
I put the mastic between the glass and the rubber.. not between the rubber and the cab..
for cleanup.. put some plastic wrap on the body, and run a piece of painters tape along the bottom edge of the sill.. then you can peal it off later..
two rows of plastic wrap will keep the goo off the bed if you have one.
string overlapped almost window length, start at the top, finish at the bottom in the middle..
Old Sep 21, 2012 | 09:27 PM
52 Merc's Avatar
52 Merc
Install the glass using the rope trick, then add the mastic after it's installed. It's a lot less messy that way.
Old Sep 22, 2012 | 05:33 PM
ssj7kids's Avatar
ssj7kids
Wayne,
Thanks for the advice...
Rear window DONE.
Old Sep 22, 2012 | 06:04 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
I sugest that you have help on the back glass, I have put in the front alone twice, but the back was a bear requiring an extra set of hands, ( My wifes) "edit" Oops, I see you already have got it, congrats
Old Sep 22, 2012 | 06:07 PM
ssj7kids's Avatar
ssj7kids
Jimmy is right... the rear window was much harder to do than the front.... Since I had already done the front one awhile ago, I thought the rear would be easy... It wasn't a big deal, but it was a lot harder than I anticipated.
scottlathrop
40
Feb 5, 2014 10:10 PM
DGMFORD
Feb 3, 2013 03:06 PM
Mustang65432
Aug 18, 2010 10:20 AM
JBradley500
Feb 14, 2010 01:32 PM
wilson3821
Apr 19, 2003 04:43 PM
