So, overhead console. Does the outside temp and compass still work?
If nothing works, then you have a very common problem with the overhead console PC board. If you do an advanced search for "overhead console fix" you will find threads on how to repair it.
If it is just one function that is out, but the display still works for temp and compass, then you might have to replace the entire PC board. They are available online and easy to replace.
To be honest bpounds I checked all the fuses, other then changing oil and filters.... I'm not fit to work on a lawn mower. The link you provided looks to be the problem, When I smack it ....It works for awhile.
I am having an issue with my trip computer. The two black buttons light up but not the screen on it. What could be the cause of this? I have checked the fuses and all the fuses are good. thanks in advance.
