Trip Computer not working
Old Aug 3, 2009 | 09:53 PM
dkkids5's Avatar
dkkids5
I have read that I can remove my trip computer and re sodier my connections. I have looked all over and can not find out how to remover the trip computer to do the repairs. Any ideas where to look for help.
Old Aug 4, 2009 | 10:27 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE. Have a look at this. click here
Old Aug 4, 2009 | 11:15 AM
UrbanXX's Avatar
UrbanXX
Before you remove the trip computer, make sure you check the fuse to you in dash cigarette lighter with an ohm meter. Also put at least 1/2 tank of fuel in the X. Turn fog lamps off.
May not fix the problem but it won't cost anything. Worth a try.
Old Aug 7, 2009 | 12:25 AM
GreenExcursion's Avatar
GreenExcursion
Mine is dim and doesn't always work... oh well.
Old Aug 9, 2012 | 07:08 PM
Tugboatchad's Avatar
Tugboatchad
ONE FUSE!
One fuse fixed our cigarette lighter, both heated seats, our blinkers, and our trip computer! We have been searching threads for 4-5 hours now and thanks to this thread we fixed it all.
Thanks guys!
Old Dec 19, 2017 | 10:01 AM
hawkrider's Avatar
hawkrider
2000 F-250 Super Duty
My Trip computer and cigg lighter is not working. I checked the fuse and the fuse is good. What am I missing? Do I have to replace the cigg lighter and the trip computer?
Old Dec 19, 2017 | 11:01 AM
projectSHO89's Avatar
projectSHO89
Which SPECIFIC fuses did you check for each function? How did you check it?
Old Dec 19, 2017 | 11:20 AM
hawkrider's Avatar
hawkrider
I pulled out and checked fuse #3 "Cigar Lighter, Data Link Connector".
Old Dec 19, 2017 | 08:16 PM
projectSHO89
HOW did you check it? Stare at it? Did you check to see if there was any power in the circuit, both before and after the fuse?
F3 has nothing to do with the overhead console.
Old Dec 19, 2017 | 08:33 PM
hawkrider's Avatar
hawkrider
yes I did a visual check. What fuse controls the overhead console then?
Old Dec 19, 2017 | 08:56 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Fuse 19
Make sure you check the fuse with a test light. It might not be getting power, so a visual is not enough.
Here is the rest of the info you need:
Old Dec 19, 2017 | 09:00 PM
hawkrider's Avatar
hawkrider
Originally Posted by Nicmike
Fuse 19
what year truck is that for?
Old Dec 19, 2017 | 09:02 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
'00 and '01
Old Dec 19, 2017 | 09:10 PM
hawkrider's Avatar
hawkrider
'00 and '01
ok. My truck did not come with one. I downloaded one from online. It said it was for 99-08.
I guess it is not the fuse since all the other stuff that showed on the fuse work.
Old Dec 20, 2017 | 05:44 AM
01__Excursion's Avatar
01__Excursion
Pretty straight forward, fuse 19 feeds 12v to the RD/YE (red w/yellow tracer) wire to the console module, check for voltage there next.
https://www.ford-trucks.com/forums/4...-gone-out.html
