Sponsored by: Real Truck
Trip Computer Problem..
Old May 31, 2010 | 09:16 AM
fshnerie's Avatar
fshnerie
I noticed it was starting to go out...It Went. Checked the fuses, but cant find a fuse just for trip computer.
This is an 04 F-350 Super Duty Crew FX4 Larait 6.0 Turbo Diesel
This is the only problem I have with this truck, bought it new and pull a boat with it.Best Truck I have ever owned.
Thanks for any info
Old May 31, 2010 | 09:20 AM
gearloose1's Avatar
gearloose1
If there is not a simple fuse problem (check the manual for which fuses).
Then.. do a reset of the computers as per below.
Old May 31, 2010 | 10:01 AM
fshnerie's Avatar
fshnerie
Thanks for the info gearloose, pulled cables off battery's. This the list of fuses I checked.
#4 Power Point Instrument Panel Good
#35 Instrument Cluster Good
#41 Instrument Cluster Good
Am I missing anything?
Old May 31, 2010 | 10:11 AM
gearloose1's Avatar
gearloose1
Did you discharge the computers by turning on the headlamp while the battery is disconnected?
If this simple fix fails, you are into first:
A) testing power at the computer -- if that test good
B) substitute a new computer.
A good parts counter person will usually lend you the part to plug in outside!
If that solves the problem... you got your answer.
Old May 31, 2010 | 10:23 AM
fshnerie's Avatar
fshnerie
Yes Lights where on, Thanks for the info..
Old May 31, 2010 | 10:43 AM
gearloose1's Avatar
gearloose1
Those electronics boxes either work or not work... so that is why a substitution test is about the only card left.
Old May 31, 2010 | 07:09 PM
bpounds's Avatar
bpounds
On an '04, isn't the trip computer in the overhead console?
Old Jun 1, 2010 | 05:13 AM
fshnerie's Avatar
fshnerie
Yes it is bpounds
Old Jun 1, 2010 | 08:04 AM
bpounds's Avatar
bpounds
Originally Posted by fshnerie
Yes it is bpounds
Then why were you checking fuses for the cluster?
So, overhead console. Does the outside temp and compass still work?
If nothing works, then you have a very common problem with the overhead console PC board. If you do an advanced search for "overhead console fix" you will find threads on how to repair it.
Start with this thread: https://www.ford-trucks.com/forums/4...-gone-out.html
If it is just one function that is out, but the display still works for temp and compass, then you might have to replace the entire PC board. They are available online and easy to replace.
Old Jun 1, 2010 | 01:03 PM
fshnerie's Avatar
fshnerie
To be honest bpounds I checked all the fuses, other then changing oil and filters.... I'm not fit to work on a lawn mower. The link you provided looks to be the problem, When I smack it ....It works for awhile.
Thank You
Old Jun 1, 2010 | 01:17 PM
bpounds's Avatar
bpounds
Yep, that pretty much means it has loose solder joints. If you can solder on a PC board, you can fix it.
Old Jun 1, 2010 | 01:24 PM
gearloose1's Avatar
gearloose1
Another case where the brilliant engineers underestimated the effects of heat shock vibration on electronics.... sigh...
Old Jun 1, 2010 | 02:48 PM
fshnerie's Avatar
fshnerie
Of all the trucks I've owned this is by far my favorite. And this has been my only problem. I'm glad I found this site, its been very helpful to me.
Thanks Again
Old Dec 14, 2020 | 09:05 PM
cbrannon57's Avatar
cbrannon57
trip computer
I am having an issue with my trip computer. The two black buttons light up but not the screen on it. What could be the cause of this? I have checked the fuses and all the fuses are good. thanks in advance.
dkkids5
Feb 19, 2018 03:35 PM
flylooper
Jun 5, 2017 03:39 PM
flylooper
Oregon Chapter
Jun 4, 2017 09:05 AM
Almost retired
6.2L V8
May 17, 2017 04:13 PM
bgilfrich
Jul 11, 2016 02:09 PM
