Door lock problem??
Old May 29, 2010 | 07:05 PM
rsx664's Avatar
rsx664
Door lock problem??
I've searched, but haven't come across this yet. I have a 1996 F350 crew cam, power door locks work like a charm, doors unlock with the key, my problem is the previous owner removed all the pull levers in the top of the door panels used to unlock the doors from the inside. I need to know how to replace these parts. I know I can get what I need from the dealer, but can someone give me a little guidance on how to fix this once I get the parts. I can't get to anything inside the rear doors without drilling out all the rivets and removing my windows/regulators.
Any help would be great............
Old May 31, 2010 | 06:59 AM
rsx664's Avatar
rsx664
anyone have any ideas or help??
Old May 31, 2010 | 07:49 AM
TexasGuy001's Avatar
TexasGuy001
Do you mean that the door lock ***** are missing? If so, you can still push the rod down to lock the door. Pulling the handle up should unlock them anyway. To replace them just get some ***** off of NPD, LMC, Ebay, or salvage yard and screw them back on.
Old May 31, 2010 | 09:00 AM
rsx664's Avatar
rsx664
no, I mean the rod itself is bent/not working/messed up. You can't push or pull the rod up/down but the power lock part works just fine.
Old Nov 2, 2010 | 12:52 PM
tubss76's Avatar
tubss76
my rear door lock will not push down or pull up door is permently locked/shut. will not open with lever. i too would like any info on this matter. 97 f30 crewcab dually power locks/windows
Old Nov 3, 2010 | 04:12 AM
TexasGuy001
If you cant get the door open you will have to pull the seat and then pull the door panel from inside the truck.
Old Nov 3, 2010 | 04:18 AM
sasafrass89's Avatar
sasafrass89
Can i get some helpe with a question? Im lookin for a lift kit for my 89 f150 & i need to know what years i can get it off of.
Old Nov 3, 2010 | 04:28 AM
TexasGuy001
Start a new thread. That is completely unrelated to this topic.
Old Nov 3, 2010 | 06:05 PM
sasafrass89
i dont know how. thats why i asked. lol
Old Nov 4, 2010 | 04:45 AM
TexasGuy001
Go here and click on new thread at the top.
1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Old Nov 4, 2010 | 09:36 AM
1Aauto's Avatar
1Aauto
Former Vendor
do the door lock actuators freeze up on these trucks causing this or is it a door lock mechanism issue.
Old Nov 4, 2010 | 10:47 PM
CJM8515's Avatar
CJM8515
I know the door locks can freeze up, in several vans (use same mech iirc) the rod itself moves just fine but the key part wont work.
Not sure how the rods on the tops of the doors dont move unless they arent connected.
hivoltj
Mar 9, 2015 12:05 PM
mtatum
Electrical Systems/Wiring
Jun 2, 2009 12:09 PM
jjs2032
Apr 22, 2008 08:27 AM
Mykro
Oct 3, 2003 02:45 PM
