Aerostar Ford Aerostar
Daytime running light module / Relay / loopback plug
Old May 28, 2010 | 08:39 PM
1995_F150_5.8's Avatar
1995_F150_5.8
I have found the plug where the DRL module plugs in. i think i have to retrofit a 1997 Aerostar to pass a Canadian inspection - is there a DRL relay up under the dash like the F150's or is it just a plug-n-play thing with the module under the hood?
Old Jun 2, 2010 | 11:34 AM
R-TypeEman's Avatar
R-TypeEman
plug the module in and it'll work, no relays to mess with
Old Jun 2, 2010 | 11:39 AM
1995_F150_5.8
i have to take that back.. there doesn't seem to be a provision for the DRL in the forward harness. is the forward harness with the DRL from a 96 swappable?
Old Jun 3, 2010 | 07:57 PM
Muffinman's Avatar
Muffinman
I think the light switch has to be replaced to, if I remember right. Its part of the delay and even has a rotary switch on the outside of it.
Old Jul 15, 2010 | 05:25 PM
1995_F150_5.8
done..
switch is the same. forward harness is different. got the DRL pig tail at the pick-n-pull all the way to the main firewall block connector... took the main block apart, swapped a few wires, spliced some more.. and it worked first try.
rxk9394
Sep 30, 2016 06:36 PM
ratedterror
Escape & Escape Hybrid
May 29, 2016 12:49 AM
RPM Chris
Apr 12, 2010 11:02 AM
fordmanss12
2004 - 2008 F150
Jun 19, 2007 02:59 PM
joyedco
Electrical Systems/Wiring
Oct 6, 2003 05:28 PM
